Old 01-28-2012, 08:53 AM   #1
alvin
alvin is an unknown quantity at this point
Fitting a R33GTR diff/stub shafts in s14 R200 diff housing?
I am trying to find the best way to build a as tough rear end as possible for reasonable money and i therefor wonder if i could buy an aftermarket R33GTR diff from for example KAAZ,CUSCO and then put it in my original S14 oem R200 diff housing and then also fit the stub shafts from a R33GTR diff. Would all this fit?
Together with this "cusom" diff my plans then are to use R33GTR axles and Z32TT 32 spline hubs.
Would this work or are the R33 GTR R200 diff housing different to the one used in the S14?
alvin is offline   Reply With Quote
Old 01-28-2012, 12:59 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Doubt it would work...GTR rear ends are physically larger than S-chassis rear end. GTR rear ends are R205. You'd be better off changing to a GTR subframe and running the R205 rear end all together with the GTR axles and hubs.
CLICK HERE!!!
Old 01-28-2012, 02:03 PM   #3
Croustibat
Croustibat is an unknown quantity at this point
Motoiq made a nice article about building a bulletproof transmission. You might want to check it out.
besides ...
Croustibat is offline   Reply With Quote
Old 01-28-2012, 04:30 PM   #4
fliprayzin240sx
besides ...
Yah, until you start twisting the axle input shaft to the hub like a pretzel.
CLICK HERE!!!
Old 01-29-2012, 05:00 AM   #5
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
I have heard that the outputshafts are the weak link. I have wondered about the possibility of them being made out of billit steel, or even cryo treating the stock ones, not that i really should need to worry about it.
4x4le is offline   Reply With Quote
Old 01-29-2012, 07:40 AM   #6
89JDM240sx
89JDM240sx's Avatar
89JDM240sx is an unknown quantity at this point
I have a S13 with a R33 GTS diff and driveshaft shop 1000hp axles... It's pretty strong
89JDM240sx is offline   Reply With Quote
Old 01-29-2012, 10:54 AM   #7
rbs14kouki
rbs14kouki's Avatar
My frind is runing a r32 gtr diff , axles and z32 hubs !!!
Sr20vet 600+ whp on mustang dyno
Its a Drag car !!!
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
