Old 11-06-2016, 07:16 PM   #1
Jpalma
Jpalma is an unknown quantity at this point
s14 95 S14 Dash lights STAY ON
95 s14 brake, battery, and oil lights staying on. Installed brand new ignition switch and same result I can turn the car on fine it will run and the lights come off but when I try to turn off it doesn't turn off it just hesitates until it dies out then the lights on the dash stay on even with the key out! What could be the problem please help! KA24DE have checked all grounds and plugs and fuses
Jpalma is offline   Reply With Quote
Old 11-07-2016, 04:31 AM   #2
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Check plus I'm the passenger and driver footwell and look for rubbed through harness in wheel wells
Old 11-08-2016, 10:56 AM   #3
Jpalma
Will check later today, thank you for the input!
Old 11-27-2016, 09:03 PM   #4
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
exactly what he said. Something is grounding out causing this. Had this problem on my S13 few years ago and turned out to be the hardness under the wheel well being chewed out due to car being lowered. GL
zylvia213 is offline   Reply With Quote
