Old 04-09-2015, 10:02 PM   #1
tekassing
tekassing's Avatar
tekassing is an unknown quantity at this point
Need check engine light to work
Hey I've been looking around but I haven't quite found the answers I was looking for.
I bought a 1993 240sx hatch with an sr20det swap and an e5 ecu
I need to get it smog legal, but the check engine light won't come on at start-up like it's supposed to. In fact none of the bulbs on that side, Low Fuel, Washer fluid, etc. light up.
The other side: parking brake, seat belt etc. all work fine. I pulled out the cluster, checked the bulbs, traces, everything was fine.
I checked the ecu and there's no wire coming off of pin 24, which is supposed to be the malfunction indicator lamp.
People say to wire that to the red wire on the cluster and that would lead to the check engine light.
Will that only light up if there's an error code, or will it light up on start-up so I can pass smog?
tekassing is offline   Reply With Quote
Old 04-12-2015, 06:36 PM   #2
that1guywithans13
that1guywithans13's Avatar
that1guywithans13 is an unknown quantity at this point
I noticed you are in Los Angeles.
an sr swap in your car= automatic smog fail.
The engines do not meet california emissions standards altogether
ITS ALL FUN AND GAMES TILL THE FLYING MONKEYS ATTACK..
that1guywithans13 is offline   Reply With Quote
Old 04-12-2015, 07:11 PM   #3
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Exactly what I was thinking?..
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 04-12-2015, 09:18 PM   #4
tekassing
tekassing's Avatar
Whoops. I did not know this. This is probably something I should've researched beforehand. Boy.
Old 04-12-2015, 10:22 PM   #5
that1guywithans13
yea.. lol. Gotta pay your drift tax every other year when your modded 😆 Welcome to the forum! Not everyone here is as nice as me but as long as you do your research before asking the forum quickly, you'll be ok lol.
s13, smog, sr20det
