Old 06-03-2012, 11:59 AM   #1
doitsidewayz
doitsidewayz's Avatar
doitsidewayz is an unknown quantity at this point
Bad Turbo seals or valve seals...?
Okay I have an s14 with an s14 notchback swap. And I don't know if it just started smoking or got it that way...when I got the car was all stock just the sr20 swap..but anyways, Motor is all stock but Rocker arm stoppers a fmic and a straight pipe. No cats or resonator. Well car smoke when I let it idle for 20+ second and I take off or rev it up. But just the first rev than it clears up. Won't smoke when driving or idling. Car still running the stock 7-8 pounds...any help? it's not that bad but I want to fix this asap. Lol
Could it be a bad turbo or valve seals.?
Also I'm running mobil1 10-50 synth. If it even matters.
I was running 5-30 and thought that was the problem but still doing it
doitsidewayz is offline   Reply With Quote
Old 06-03-2012, 12:03 PM   #2
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
what color is the smoke
ch1873857 is offline   Reply With Quote
Old 06-03-2012, 12:06 PM   #3
doitsidewayz
Grayish.
I also noticed it does it more when the car is warm
Old 06-03-2012, 12:27 PM   #4
ch1873857
do a leak down test....
Old 06-03-2012, 03:52 PM   #5
JdmDrift4Food
JdmDrift4Food's Avatar
JdmDrift4Food is an unknown quantity at this point
Do you know anyone with a spare turbo to test? If its a journal bearing turbo, it sounds like the seals are slowing going bad. But it also could be the valve seals like you said because I had the same issue on my old car, and I replaced the valve seals and no more smoke!
JdmDrift4Food is offline   Reply With Quote
Old 06-03-2012, 03:55 PM   #6
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Usually smoking at idle is the turbo seals, my car would randomly smoke at idle for a good 20 seconds. I replaced my turbo and it hasn't happened since.
Old 06-03-2012, 04:08 PM   #7
doitsidewayz
Yeah it won't smoke at idle dude. Just smoke when it sits and i take off. Than it clears. I can let the car sit at idle for 1hour and no smoke would come put until I take off.
Old 06-03-2012, 04:10 PM   #8
pacotaco345
pacotaco345's Avatar
sounds like your valve seals..
Old 06-03-2012, 04:12 PM   #9
JdmDrift4Food
Pretty sure its the turbo then. I thought bad valve seals smoked at idle and stoped a little ways after you get on the gas. Could be either or. Maybe even rings going bad. I would start by replacing turbo if you have access to a un-blown one, or as stated above, do a leak down test.
Old 06-03-2012, 04:34 PM   #10
doitsidewayz
I'm so confuse... Lol
How much is it to get valve seals replaced any ways?
Old 06-03-2012, 04:44 PM   #11
JdmDrift4Food
Its around 60-80 for the seals iirc. And you can do them yourself if you have any mechanical knowledge.
Old 06-03-2012, 07:19 PM   #12
s14>integra
s14>integra will become famous soon enoughs14>integra will become famous soon enoughs14>integra will become famous soon enoughs14>integra will become famous soon enoughs14>integra will become famous soon enough
definitely sounds like valve seals if it smokes when you take off after letting it sit for awhile. You can change them yourself just make sure you don't drop a valve into your motor otherwise you will be doing a lot of extra work.
s14>integra is offline   Reply With Quote
Old 06-03-2012, 07:39 PM   #13
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
If it is the valve seals, why would you only do the seals? The valve guides probably need some replacing too.
But I'd check to make sure first that its not the turbo. Take the inlet off and check for shaft play. As long as you dont have much in and out play, it should be good.
CLICK HERE!!!
Old 06-03-2012, 07:55 PM   #14
MrSanchez925
MrSanchez925 is an unknown quantity at this point
Does the car smoke right away on cold starts?
90% of the time bad valve seals will cause smoke upon cold starts.
MrSanchez925 is offline   Reply With Quote
Old 06-03-2012, 08:36 PM   #15
projectblak
projectblak is an unknown quantity at this point
Mine never smoked at idle or even part throttle, cold or warmed up, but would only smoke when I get into boost.. Turned out my $2800 hks turbo was taking a shit on me and the oil seals were going out.. Gl op
projectblak is offline   Reply With Quote
Old 06-03-2012, 09:10 PM   #16
doitsidewayz
^^^ lol
I can step on it when I'm driving it and won't smoke at all dude ....I can let the car sit at idle fr hours from a cold start and won't smoke. It smokes when I rev it up after the car is sitting down For maybe 20+ seconds. But than it clears up...
Old 06-03-2012, 09:13 PM   #17
projectblak
Take off ur filter and piping and see if there is any oil in them mine had plenty of oil. If there is then probably ur turbo seals
Old 06-03-2012, 09:37 PM   #18
doitsidewayz
I Check every single thing last night, checked cold side pipping, hot side, and intake pipe and no signs of oil at all...
Old 06-03-2012, 09:44 PM   #19
projectblak
Maybe valve seals? Don't think I'm much of help now lol
Old 06-03-2012, 10:37 PM   #20
doitsidewayz
i guess...thanks anyways dude
Old 06-04-2012, 05:29 AM   #21
projectblak
Np good luck man
Old 06-04-2012, 08:08 PM   #22
JdmDrift4Food
Originally Posted by Joseph89 View Post
look good
Da fuck? LOL fucking spam..
Old 06-05-2012, 01:34 AM   #23
doitsidewayz
Hahahaha in saying...I didn't k ow what to reply back to that one hahaha
Old 06-06-2012, 01:46 AM   #24
ryublack
ryublack's Avatar
ryublack is an unknown quantity at this point
240sx for sale take a look
Nissan : 240SX Nissan : 240SX | eBay
ryublack is offline   Reply With Quote
Old 06-11-2012, 04:49 PM   #25
doitsidewayz
Okay found the problem...did not have a bad turbo or valve seals.
Just had a little to much oil and it was burning it off. Silly me!!
Thanks a lot guys!
Old 06-11-2012, 04:51 PM   #26
doitsidewayz
^^^^ what's up with this random comments on my thread lol
Old 06-11-2012, 07:14 PM   #27
doitsidewayz
-___________-
