Old 12-12-2019, 08:44 PM   #1
clunkier_tripod
clunkier_tripod is an unknown quantity at this point
Help With JDM s14 Silvia Steering Hub
ok I have searched this but being a jdm model in America it seems difficult to find info. I have a 1993 Silvia s14 qs. it has a non airbag steering wheel. I've tried installing a short hub on the car but there seems to be a nice gap between the gold plate on the hub and the metal prong on the actual switch mechanism. I just want my horn to work but im wondering if I need a special kind of hub. I thought they were all the same but my s13 the horn worked with the same short hub. any help would be awesome and I will answer any questions. please and thank you
clunkier_tripod is offline   Reply With Quote
Old 12-13-2019, 07:01 AM   #2
S14rebuild
Horn wires come from the clockspring, should pass thru the hub n connect to the hirn button. Purchase a hub that allows for the wire to pass thru it and then connect to horn button
Old 12-17-2019, 12:29 PM   #3
gaz_moose
gaz_moose is an unknown quantity at this point
I just made my own prong out of some stiff wire.
gaz_moose is offline   Reply With Quote
Old 12-19-2019, 07:46 AM   #4
jedi03
+1 just get a wire extension of sorts and a horn button that fits!
