![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
Sr20det engine harness with painless kit
basically i have a painless harness in my s14 with a s13 sr i am changing out the engine harness from a s13 harness that was converted to s14 to just a normal s13 sr harness and i was wiring the harness in for power and saw this chart from frsport.com
sr wire color ka wire color function Black / Pink stripe Black / Pink stripe Fuel pump relay Green / Orange stripe Green / Orange stripe Transmission neutral switch Red / Black stripe Red / Black stripe ECU relay Green / Yellow stripe Green / Yellow stripe* AC relay Black / White stripe Black / White stripe ECU power Blue / Green stripe Blue / Green stripe AC relay Black / Yellow stripe Black / Yellow stripe Idle air control solenoid power Brown Any +12V Switched** O2 sensor power Red Red ECU backup power Black / Red Blue / Red Black / Red stripe Main ignition power the only ones that i think matter are the ecu power back up ecu power and main ignition power but my car was still surging while at idle do i need to wire up the Idle air control solenoid power???? What does everyone else wire up to the engine harness when they do a painless kit? I figure i am not giving power to something thats making it surge. Also my alternator is putting out 15 volts and i am just giving power to the bottem wire of the alternator plug is this correct? |
