How can I put my windows up (s14)
Yes sounds dumb I know. but i bought a drift car (s14 Silvia) and the drivers window won't go up for a couple reasons. The whole door panel has been replaced with a peice of sheet metal with no switch on it and probably no wires or anything running to the motor. And also I can't pull it up as its stuck. So how can I at least be able to pull the window up. I'll be using it for drifting so I'll mostly have it down anyway but I need to be able to pull it up so it doesn't get soaked with water on the inside. If I remove the regulator will the window just fall or will I be able to manually raise and lower it? What should I do? Thanks
remove the regulator and pin it up...use long pin so you can actuate it without having to take panel off each time...I thought about doing this: aluminum panel for door panel w/decent arm rest, slots with handle/bolts/whatever can grab to move window up and down and simple slide lock to lock it in the up position...
![]() Join Date: Dec 2004
Trader Rating: (58)
You're going to need to use the switch to make it operate any any fashion.
You're other option is to remove the window completely, goto home depot and get some bathroom lexan or what not, and then fab a 'window' that you can put in and remove for transport/keeping the water out. Not a hard job either.
![]() Join Date: Jun 2003
Trader Rating: (129)
step one: remove the big metal sheet
step two: inspect whats ACTUALLY there step three: ????? step four: profit if all the factory wiring and motor is still in place, just wire a toggle switch to it and go about your day. if its NOT there, you've got some figuring to do. . . . maybe retrofit some wiring and a motor from a donor door afaik no s14 came with manual windows, so I don't know if it would be a huge pain to MAKE it operate as manual. |
Tags |
s14 |
