Old 01-15-2012, 07:58 AM   #1
Prelude Guy
Prelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymorePrelude Guy is not welcome here anymore
Question for people with TEIN tie rods
Hi guys,
I have a question. Are there any additional parts that come with these that aren't shown in this pic?
Tein Inner & Outer Tie Rods Combo S13 S14 S15 240SX SILVIA
I was wondering which parts are used to increase the steering angle. If all the parts included are shown in the pics, are the washers the only parts used to increase steering angle?
Thanks!
Prelude Guy is offline   Reply With Quote
Old 01-15-2012, 08:44 AM   #2
Sileighty_85
Sileighty_85's Avatar
if you look at the 2nd pic you will see 2 thick washers, Those are what increase steering angle
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-15-2012, 09:11 AM   #3
silly240
silly240's Avatar
silly240 is an unknown quantity at this point
Thats everything, just be prepared to rub if you add the washers on a low offset wheel
silly240 is offline   Reply With Quote
Old 01-15-2012, 04:13 PM   #4
Prelude Guy
Ah, I see. Thanks guys!
I was expecting some metal/aluminum plates or something. Had no idea it was just washers.
Thanks again!
Old 01-15-2012, 04:35 PM   #5
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
best bet is to buy the parts shop max spacers. only ten bucks but they're 7mm vice the 6mm tein ones. MAKE SURE YOU USE LOCTITE, the factory lock plates will no longer work and it's imperative you use locktite (i use blue, red is overkill).
sidewaysil80 is offline   Reply With Quote
