Old 08-20-2010, 12:18 PM   #1
xSRsil80x
xSRsil80x is an unknown quantity at this point
tie rod help!currently outside working on it.
my tie rod end is giving me issues..
the bolt that you put the nut/pin on is pratically spinning freely.
this is making it rather difficult to tighten.
is there something im doing wrong or do i just need a new tie rod end....
helap!!!!
xSRsil80x is offline   Reply With Quote
Old 08-20-2010, 12:45 PM   #2
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
use a impact gun.
Slammed Assassin is offline   Reply With Quote
Old 08-20-2010, 12:56 PM   #3
slideslidegnarslide
slideslidegnarslide is an unknown quantity at this point
^^^^ you stole the words right out of my mouth(key board i guess)
slideslidegnarslide is offline   Reply With Quote
Old 08-20-2010, 12:57 PM   #4
xSRsil80x
i dont have one.=(
is there any other solution?
Old 08-20-2010, 01:09 PM   #5
slideslidegnarslide
uhhmmm not really sadly thats the only thing ive ever goten to work
Old 08-20-2010, 01:41 PM   #6
Sam_Well.13
Sam_Well.13 is an unknown quantity at this point
are these used or brand new? usually brand new ones wont spin. Id suggest for you to make some phone calls and see i any of your friends have lifetime warranty @ autozone.
I just changed mine 1 week ago and no problem.
but when i did, and i didnt have an impact gun. i had to hold the stud with a vice grip and tighten the bolt, but that causes you to ruin and spill some grease that are inside the tie rod end joints.
if you were working with OEM replacement that is.
Sam_Well.13 is offline   Reply With Quote
Old 08-20-2010, 08:33 PM   #7
c72c
c72c's Avatar
Trader Rating: (25)
c72c is an unknown quantity at this point
Feedback Score: 25 reviews
put pressure on the underside of it. i.e. put a jack under it, jack it up some, and tighten it.
if you don't have a jack, tap the underside with a hammer while you tighten it.
if all else fails, buy a new one.
c72c is offline   Reply With Quote
Old 08-20-2010, 08:40 PM   #8
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
If you use a wrench sometimes they will spin new. shit just happens. You have a few options. Either put pressure on it with a jack. Or clamp it with a vice grip, or run the impact on it till it grabs.
smoked240 is offline   Reply With Quote
Old 08-20-2010, 09:57 PM   #9
xSRsil80x
forgot about this thread. lol
i just ran out and got a new outer as well.
which was exactly the problem.
thanks for the help guys.
Old 08-23-2010, 02:55 AM   #10
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
yep just put pressure from bottom up, ie put a jackstand under it
supreme_1 is offline   Reply With Quote
