Old 11-26-2012, 02:40 PM   #1
spineshankzx
spineshankzx's Avatar
spineshankzx is an unknown quantity at this point
LOTS of S13/S14 parts! ALL MUST GO
UPDATED ***11/16*** EVERYTHING MUST GOOOOOOO
S13 Hatch/Coupe
Drivers side Power Door Panel-----$30
Dash has ONE minor crack------------- $75
(2) Seat Belt Control Computers ---$10
A Pillar Trim (both Pieces)--------------$20
Front Blinkers -----------------------$30
(2) Washer Fluid Resevior
Stock Throttle Pedal
Kicker Panel Trim w/ Fuse Cover
Headlight Bulbs
Stock Fuel Pump
YELLOW Headlight Bulbs
KA24DE Apexi N1 Dual Exhaust with Welded cat --------SOLD
Complete Header back exhaust with cat delete
S13 Center Console
DNA Racing Strut Stabilizer Bar ----------$50
2 12" Fans
Coupe Taillight Panel (Rear Right)
E Brake Trim Piece
Power Window Switch
Rear Ash Tray
Ash Tray
Passenger side Courtesy Light
2 Throttle Pedals
Cluster Buttons
Seat Mount Trim
HID Kit what you see is what you get
Steering Column
SunPro Boost Gauge w/ Pod
S14 Trunk/Gas Release
OEM Shift Knob
Hood Prop Rod
OEM Climate Control Unit
SR20DET Stock Valves/Springs/Retainers
Both Power Window Inner Trim
Brake Booster and MC
Right Rear Speaker Cover
Ka24DE Ignition Coil
SR20det AC Pulley
Door Handle Trim
Headlight Trim "L" Side
S14
S14 Steering wheel AIRBAG
S14 Rear Caliper (not sure what side)
S14 Rear Seatbelt Buckles
S14 Dash Air Vent Trim
S14 Various Trim Steering Column, Under Column, Door Jambs,
S14 Blower Motor/Heater Box ----------$30
S14 Rear Speaker Cover Panel ---------$40
S14 Steering Column and Ignition w/key -----------$100 NOT SHIPPING
S14 Visors ---------$30
S14 AC Electric Fan/Condensor --------$50
S13/14 Clutch Fans/ Electric Fans -------$20
Hood Hinges
E Brake Handle and Assembly no lines
Hood Pull Cable
Coolant Resevior
Thanks for looking!
-Rick
spineshankzx is offline   Reply With Quote
Old 11-27-2012, 11:35 PM   #2
Tbone240
Tbone240 is an unknown quantity at this point
interior passenger side plastic piece for s14 SE? it holds the power lock and window switches. Also the power steering tensioner bolts? High pressure power steering line?
Tbone240 is offline   Reply With Quote
Old 11-29-2012, 05:12 AM   #3
spineshankzx
Sorry, None of those
Old 11-29-2012, 09:18 PM   #4
Nixonz
Nixonz is an unknown quantity at this point
how much for kick pannel trim fuse box cover shipped to canada alberta red deer
Nixonz is offline   Reply With Quote
Old 12-05-2012, 03:00 PM   #5
spineshankzx
PM'd updated
Old 12-08-2012, 04:17 AM   #6
xinfinitix240sx
xinfinitix240sx's Avatar
xinfinitix240sx is an unknown quantity at this point
Send a message via Yahoo to xinfinitix240sx
Do u have front right lower control arm for a s14
xinfinitix240sx is offline   Reply With Quote
Old 12-08-2012, 05:20 AM   #7
spineshankzx
no sorry
Old 12-11-2012, 11:18 AM   #8
spineshankzx
Bump tttt ignition coil sold
