Old 12-04-2009, 07:18 PM   #1
jin8544
jin8544's Avatar
jin8544 is making his/her stupidity well-knownjin8544 is making his/her stupidity well-knownjin8544 is making his/her stupidity well-knownjin8544 is making his/her stupidity well-known
s13 sunroof question
I just bought s13 with sunroof and scared of opening it lol
the rubber seals dont look that bad but from my past experiences it always leaked.
but to the point, i read that on s13 sunroof they have hoses that run down a-c pillar for water. is this true?
i really want to open it but i sm going to be taking this car to chicago and do not want to worry about leaking
does anyone have sunroof covers for sale?
jin8544 is offline   Reply With Quote
Old 12-04-2009, 07:54 PM   #2
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
Yes they are Sunroof Drains - They run down all 4 pillars.It would be leaking now if it was - Tubed are the diameter of a Nickel just about.Attached to the Track.
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 12-04-2009, 07:56 PM   #3
Matej
Yes it is true.
I do not think I have ever driven my car with the sunroof closed.
Old 12-04-2009, 08:11 PM   #4
jin8544
jin8544's Avatar
okay so it wont leak then ?
anyone have the covers!?
Old 12-04-2009, 08:38 PM   #5
sliksta1
sliksta1's Avatar
sliksta1 has a spectacular aura aboutsliksta1 has a spectacular aura aboutsliksta1 has a spectacular aura aboutsliksta1 has a spectacular aura aboutsliksta1 has a spectacular aura aboutsliksta1 has a spectacular aura about
well there is a possibilty the drain hose may have a leak in it too. i had this problem in old hatch. but that was cuz i think the previous owner messed with it. chances are little that you would have this problem though.
sliksta1 is offline   Reply With Quote
Old 12-04-2009, 09:00 PM   #6
projectRDM
projectRDM's Avatar
Since you're asking for a cover, we'll assume it's a hatch. You didn't say. The hoses are about the size of a dime more like, located at each corner of the roof channel, they drain down each pillar into the rocker panel, and out through drain holes. They can get clogged though, dirt, debris, anything that would normally poll up around the opening, so it's best to flush them all with water and verify they do indeed drain out, just look for a puddle under each corner of the car.
FORMERLY R240NA
