Old 04-16-2015, 11:14 AM   #61
JRex
JRex is an unknown quantity at this point
Oh i thought you were referring to where the brackets mounted to the block. I haven't heard anything about the actual mounting bolts on the mounts being offset...that's a new one. Are those mounts side specific?
Never Due
JRex is offline   Reply With Quote
Old 04-16-2015, 11:19 AM   #62
Albert_Trd
Albert_Trd's Avatar
Albert_Trd is an unknown quantity at this point
im not sure. they are identical, so id assume you can swap the between right side and left. im gonna wait till i have the sway bar removed and re-test fitment before I jump to conclusions.
~755whp 1jz.~ Proefi 128, e85, 1200cc, 6265, 39psi
Albert_Trd is offline   Reply With Quote
Old 04-17-2015, 10:47 PM   #63
Drift_Squad144
Drift_Squad144's Avatar
Drift_Squad144 is an unknown quantity at this point
Update got some stuff:
-slave cylinder
-power steering line
-walbro 450 fuel pump
Etc.
Sent from my iPod touch using Tapatalk
Drift_Squad144 is offline   Reply With Quote
Old 04-18-2015, 01:54 AM   #64
Cronus577
Cronus577's Avatar
Cronus577 is an unknown quantity at this point
Awesome build. Love how meticulous you are with the parts. looks amazing!
Cronus577 is offline   Reply With Quote
Old 04-18-2015, 07:46 AM   #65
Drift_Squad144
Thanks man I appreciate it.
Old 04-18-2015, 01:39 PM   #66
Royal_T
Royal_T's Avatar
Looking good bro
http://zilvia.net/advertise.html
Old 04-18-2015, 02:52 PM   #67
Drift_Squad144
Originally Posted by Royal_T View Post
Looking good bro
Thanks!!
Old 04-21-2015, 03:18 PM   #68
Drift_Squad144
Got my purple BOV!!
@Drift_Squad144
Old 04-22-2015, 09:52 PM   #69
Albert_Trd
Albert_Trd's Avatar
Removed the battery tray today
Also removed the sway bar so we tried fitment again:
Old 04-23-2015, 10:09 AM   #70
JRex
Anymore fitment issues? Did you ever figure out the mounts?
Never Due
Old 04-23-2015, 11:45 AM   #71
Albert_Trd
Albert_Trd's Avatar
I had to take swaybar out, cut the spare stud off the mounts and both aim them the same direction. And everything works fine. More than likely now seeing how much room i have, will go straight through mounts. should push motor back toward firewall 1/2''. the trans mount is slotted and has room to go back
Old 04-23-2015, 01:54 PM   #72
Albert_Trd
Albert_Trd's Avatar
New wheel test fit
9.5+22
265/40
235/40
Old 04-26-2015, 06:44 PM   #73
Sforteen
Sforteen is an unknown quantity at this point
Originally Posted by Albert_Trd View Post
Thanks! Ive worked on my brother in laws Rb26, and id still take a 1j.
Whaaaat, no RB love? I love mine, but i can see why people love the 1J its a great engine too.
Do you have a dyno graph of your setup? Curious to see what the power band looks like, my RB makes simular power.
Sforteen is offline   Reply With Quote
Old 04-26-2015, 07:30 PM   #74
Heywood Jablomie
Heywood Jablomie is an unknown quantity at this point
Love how clean that motor is, going to be so nice not having a greasy old thing in the bay. Are you worried at all about how low the pan sits? Not sure how low you run your car but if its very low I'd be worried about that, especially since you cant replace it easily like on an sr or a ka.
Heywood Jablomie is offline   Reply With Quote
Old 04-26-2015, 07:31 PM   #75
Cronus577
Cronus577's Avatar
New wheel test fit
9.5+22
265/40
235/40
Looks great! keep the updates coming! What Engine management are you going to use?
Old 04-26-2015, 08:51 PM   #76
el_tapatio
el_tapatio's Avatar
el_tapatio is an unknown quantity at this point
This build is so awesome! I think I'm ordering a 1j f for sure next month!
el_tapatio is offline   Reply With Quote
Old 04-27-2015, 11:57 AM   #77
[email protected]
Scott@FontanaNissan's Avatar
Scott@FontanaNissan is an unknown quantity at this point
Send a message via AIM to Scott@FontanaNissan
this car is looking awesome, love the attention to detail (to be expected from a machinist) really interested in that CD009 adapter. keep up the good work sir!
Juan Vargas - Motorsports Specialist Fontana Nissan/Nissanraceshop.com
email: [email protected]
Scott's Personal Website/Blog: http://www.scottandkerryann.com
Scott@FontanaNissan is offline   Reply With Quote
Old 04-28-2015, 08:59 AM   #78
Albert_Trd
Albert_Trd's Avatar
This was the old dyno 2 years ago on a 70mm:
This was going down to a 62mm billet:
made a little better peak, but died off up top.
The Pan is off a IS300, we are going to swap it out to the lower profile aristo pan, and raise the motor mounts back up to 2.500". Right now it is at 2.250"
once a sway bar is on, it should "protect" the pan
Thanks!
Yeah, the same OCD (being in quality) helped determine the Zerolift mounts are NOT that great. Was definitely a disappointment.
Old 04-28-2015, 09:02 AM   #79
Albert_Trd
Albert_Trd's Avatar
Anyway.
A little more headway with intercooler setup and piping. Just mocked up:
Old 04-28-2015, 04:13 PM   #80
DanielS14
DanielS14 is an unknown quantity at this point
looks like your keeping a/c?
cool stuff man!
DanielS14 is offline   Reply With Quote
Old 04-30-2015, 10:34 AM   #81
Albert_Trd
Albert_Trd's Avatar
cool stuff man!
Yes
Havent had much time to spend on the car making exhuast, intercooler, radiator fab, or anything else due to the fact of spending the past 4 days On trying to fix these Zerolift brackets. IMO these swap brackets are garbage for the money you spend on them. In the supra world, our brackets fit dead nuts, no bullshit, and I make solid motor mounts for the supras, Im a vendor over on supramania.
Trying to fight the engine from being crooked, not level, and rotation, has left me to making custom one off mounts which is a huge annoyance. I will make a new thread to show you all my troubles and my findings later.
Old 05-03-2015, 01:25 AM   #82
sulik
sulik is an unknown quantity at this point
Hey Mate, can you explain please what oil pump bypasses you drilled out? I have read about it on SF but never found some pictures of this mod...
sulik is offline   Reply With Quote
Old 05-03-2015, 10:01 AM   #83
kooky
kooky's Avatar
kooky is an unknown quantity at this point
Subscribed! Doing a 1jz swap as well, just going with a conservative single and standalone! Your build looks awesome! Keep it up man
kooky is offline   Reply With Quote
Old 05-04-2015, 05:06 AM   #84
AzS13hatch
AzS13hatch is an unknown quantity at this point
Great work man! I have a 1jz in my S13. I'm outta Tucson and would say we should meet up when this gets done, but I'm stationed in Korea right now. Either way man, good luck on finishing the build. Also, I haven't heard of anyone fitting the stock sway bar on with a JZ without spacers. Sikky makes a sway bar for LS swaps and fits around the JZ pan as well, might be worth looking into.
AzS13hatch is offline   Reply With Quote
Old 05-11-2015, 09:24 AM   #85
Albert_Trd
Albert_Trd's Avatar
Havent done much since the whole Zerolift bracket issue. But some small stuff has gotten done:
Trimmed bumper to allow Intercooler to sit forward/upright. also cut out the excess frame overhang to allow routing of the Intercooler. Then mounted the bottom with some brackets I made.
Also Started Radiator mock up. Trying to get Supra radiator with OEM shroud and clutch fan to work first before trying to get anything else to work. We have a set of ford contour fans too but I feel its the same thickness as clutch fan.
Just need a GE fan blade, that should pull rhe fan blade closer to the upper radiator pipe.
Old 05-11-2015, 12:32 PM   #86
Albert_Trd
Albert_Trd's Avatar
Here is the thread I made regarding the swap brackets for anyone interested. There was still some small things that I left out, but you get the idea.
http://zilvia.net/f/showthread.php?t=603087
Old 05-13-2015, 09:55 AM   #87
Albert_Trd
Albert_Trd's Avatar
Got A little more done:
Got a GE fan blade on, looks like its gonna work out nicely.
Also got the cold side Intercooler piping all tacked up 1-piece and fits beautifully.
and BOV tacked:
Todays goals are to finish the hotside intercooler, and tack back up the hood latch sheet metal to the intercooler for added bracing, and of course for the hood and headlights to bolt back on.
Old 05-13-2015, 02:00 PM   #88
JRex
Making good progress. That radiator/fan setup almost looks OEM.
Never Due
Old 05-13-2015, 02:41 PM   #89
Albert_Trd
Albert_Trd's Avatar
Thanks, yeah its pretty much what we were gonna go for. Its the same radiator/shroud/fan setup on my supra, so it shoudnt have any cooling issues. plus there is room in the shroud to add the two OEM electric fans to turn on when the A/C gets turned on to help with dissipation.
Old 05-13-2015, 02:50 PM   #90
[email protected]
Juan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura aboutJuan@Fontananissan has a spectacular aura about
Again,
as expected from a machinist, the Mechanical fan is a huge advantage over e-fans. good job so far keep up the good work!
-Juan
P.S. That CD009 Bellhousing adapter. still curious about it!
Juan@Fontananissan is offline   Reply With Quote
