Old 11-04-2008, 01:27 PM   #1
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
Torque specs
Im going to be doing a complete suspension overhaul pretty much everything suspension wise is going to be remove,cleaned,replaced but i want to know how important is to torque bolts down and where do i get torque specs for the suspension. Also whats a easy to use torque wrench under 60 bucks???
redline racer510 is offline   Reply With Quote
Old 11-04-2008, 01:30 PM   #2
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
i believe heavythrottle.com has the s14 fsm. go there and download it. It will have all the information you need for suspension.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 11-04-2008, 02:55 PM   #3
redline racer510
Naw i got s13 or is it the same torque specs for both? I have seen people just tighten it up and they run fine whats your take on all of this???
