Old 01-12-2012, 04:46 PM   #1
xHellaFlushS13x
xHellaFlushS13x's Avatar
xHellaFlushS13x is an unknown quantity at this point
s13 KA24e to SR20de swap
I'm doing a swap to a SR20de in my 90 240 and I'm looking for help. Engine is in the car. Need wiring advice. Also what hoses to get. Basically anything you think would help. Thanks.
xHellaFlushS13x is offline   Reply With Quote
Old 01-16-2012, 12:34 PM   #2
freeagent3117
freeagent3117's Avatar
freeagent3117 is an unknown quantity at this point
This is what I used for the engine harness.
SR20DET Swap Engine Harness Wiring Diagram Guide SR SR20
The lower harness is the same, just dont need two plugs off tranny(only use speed sensor)
Heres the vacuum lines
S13 Vacuum Diagram : SR20DET Forum (rear-drive)
Not sure what else you need.....
freeagent3117 is offline   Reply With Quote
Old 01-17-2012, 02:44 PM   #3
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
Are you putting an n/a sr or a turbo one? There's info everywhere.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 01-17-2012, 03:13 PM   #4
zombiewolf513
and you need the KA water temp sensor installed on the SR if you want to maintain your temp gauge.
Go wiring specialties, chyea
Old 01-20-2012, 12:23 PM   #5
xHellaFlushS13x
It's an S15 SR20 NA. And so far I've handled everything. The wiring is a whore but hopefully it goes well. We're using the SR harness with a few KA plugs. Zombie is that Your RPS in the picture?
Old 01-20-2012, 03:28 PM   #6
zombiewolf513
Nah, my RPS is in my build thread \/ down there.
I just did an S15 SR swap on her too!
Old 02-07-2012, 04:44 PM   #7
wiring specialties
wiring specialties's Avatar
wiring specialties is an unknown quantity at this point
OP, We can help if you are interested.
wiring specialties is offline   Reply With Quote
Old 02-07-2012, 05:23 PM   #8
h2v7
need a dohc cluster too right
Old 02-18-2012, 07:51 AM   #9
zombiewolf513
Would he?
msglength
