need help in philly area
We are building a track only s13 coupe with an sr. Almost done motor is in and turns over but I am not getting any spark. I am running an engine harness only, with switched powers and a push button start. I have eliminated almost everything. I believe one of a few things is happening. Either the ecu is not turning on and therefore not sending a signal, or the ecu is turning on and not sending a signal because either something is not hooked up or not receiving a signal, or the power fc is bad. The power fc is tuned for stock sr with a z32 maf. If anyone in the area is willing to let me plug in the power fc to their running setup to see if the power fc is the problem please contact me. Also if anyone is a wiring guru and is familiar with the setup we are running and willing to come to the car I would be willing to work something out.Thanks,
JKP
