Closed Thread
Old 12-16-2015, 11:31 AM   #1
r20crazy
r20crazy's Avatar
Trader Rating: (41)
r20crazy is an unknown quantity at this point
Feedback Score: 41 reviews
Exclamation Skullworks KA oil block x3. new unused.
ALL are sold. SOLD SOLD SOLD
I have ZERO (2 pictured) unused SKULLWORKS legit KA (works on DE or E blocks) oil blocks I had for 3 different ka-t projects. real deals not copies. You will need to purchase 2 fittings for the connections as I pulled them for use in a dry sump setup. also if u don't need to use the 3 sensor/gage ports you will need to source up to 3, 1/8" NPT (aka pipe thread) plugs, which can be found at home depot.
these blocks are -8 AN sized. the fittings (need 2) needed to use these are in link below. A regular AN fitting on oil block side will not work. for mounting oil block to engine after removing stock oil filter mount, order a new paper gasket or us grey RTV silicone just don't clog ports.
http://www.jegs.com/i/Russell/799/670700/10002/-1
SOLD SOLD SOLD SOLD SOLD
Originally Posted by Your240sucks;
Dont really want to lowball you but Will you pay me too pick it up?
Last edited by r20crazy; 01-15-2016 at 02:58 PM.. Reason: clarify fittings needed. all sold
r20crazy is offline
Old 12-16-2015, 01:17 PM   #2
95_S14
95_S14's Avatar
Trader Rating: (108)
95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future95_S14 has a brilliant future
Feedback Score: 108 reviews
legit !!!!!!
Www.PowerAutosports.com
95_S14 is offline
Old 12-16-2015, 01:50 PM   #3
Solo70510
Solo70510's Avatar
Solo70510 is an unknown quantity at this point
I PMed you!
Solo70510 is offline
Old 01-08-2016, 12:47 PM   #4
r20crazy
r20crazy's Avatar
Trader Rating: (41)
ONLY ONE LEFT. PM ME. 1st pm gets dibs.
r20crazy is offline
Old 01-15-2016, 02:59 PM   #5
r20crazy
r20crazy's Avatar
Trader Rating: (41)
ALL sold. thank you. please close/lock thread.
r20crazy is offline
Closed Thread
