Old 03-08-2016, 12:44 PM   #1
kouki_k1d
kouki_k1d is an unknown quantity at this point
Question 240 sunroof
im trying to reopen my sunroof, previous owner sealed it off, every single sunroof i found so far, not many, is a different size from mine. i heard that there are different sized sunroofs but at the same time im hearing that they are all the same size. i assumed that they were all the same. i need some clarity here cause im lost and confusedconfused:. does anyone know about 240 hatch/fastback sunroof sizes???
kouki_k1d is offline   Reply With Quote
Old 03-09-2016, 05:15 AM   #2
Tyler_240
Tyler_240 is an unknown quantity at this point
Is it the sunroof style where it opens completely, or a moonroof where it just pops up?
I know there are some other nissan vehicle sunroofs that you may be able to consider, I could be wrong, but you may want to check out a pathfinder sunroof. Might be easier to find in a pick your part...
Tyler_240 is offline   Reply With Quote
Old 03-09-2016, 08:09 AM   #3
Itsuki Takeuchi
Itsuki Takeuchi's Avatar
Itsuki Takeuchi is an unknown quantity at this point
yea tyler_240
for a glass sunroof, a nissan pathfinder (i used to replace mine) uses the same one and some nissan hardbody trucks have them. i piad $15 at my pic n pull. and you most likly wont find a 240 at a junkyard anymore. look for the pathfinders or pick ups
Itsuki Takeuchi is offline   Reply With Quote
Old 03-10-2016, 11:55 PM   #4
kouki_k1d
i learn something new every day didnt know that those matched up b ut i still dont think it answers my question as to are all the sunroofs the same or different sizes
Old 03-11-2016, 08:32 AM   #5
Itsuki Takeuchi
yes. all hatchbacks/fastbacks are the same.
coupes are different and are electrical so it will not work
s14s are also electric
Old 03-11-2016, 12:57 PM   #6
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
my coupe has just a pop up one that looks aftermarket to me, some other brand on the glass and it leaks so i just sealed it up
HellaSexyS13 is offline   Reply With Quote
Old 03-16-2016, 05:50 AM   #7
Tyler_240
Remember 240s have a drain built in...pop up your moon roof and towards the back corners are the holes...if its aftermarket you may want put a hole there and the run a hose down your a or b pillar to the ground
Old 03-20-2016, 07:12 PM   #8
billyblaze
billyblaze is a well-known jackass
The pathfinder is only for the s13
I have a 98 s14 glass good
But the frame of it is jacked up
And that i ther trim piece broken
Car is ready for paint but need to get sunroof fixed
I leaks like crazy now
[email protected]
If needed for some reason i cant view my pms
billyblaze is offline   Reply With Quote
