Old 10-06-2020, 09:46 PM   #1
SidewayzAsFck
SidewayzAsFck can only hope to improve
Thumbs up Fall sale! 240sx, LS, and SR parts for sale!
Parts for sale (buyer pays shipping & PP; only shipping certain
<bold> LS parts </bold>
- WIring specialty ls1 - s14 BNIB harness (interface harness pretty and labeled for RHD chassis) + 411 PCM - $550
Lm7 truck intake - $85
Lm7 starter - 50
Rear sump LS oil pan - $175
T56 trans mount bushing x 2- 35 each
S13/s14 bmc heat shield - $60
<b>SR20det parts </bold>
Sr Comp clutch lightweight steel Flywheel (BNIB)- $270
Custom aluminum solid Sr/KA mounts -$125 (used for 800hp race car)
Used rps max Sr20det clutch setup - $195
ACT 6 puck sprung clutch disc (BNIB) ? $150
Koyo release throw out bearing (brand new & installed) - $50
Jgs fuel rail - $50
Coil pack harness - $50
Bings Coil pack cover w/ jdm black oil cap and bolts- $70
Peak performance Sr20det pro trans mount (slightly modded) -$35
4 sr20det coils - $100
Sr20det starter - 125
SR20DET oem alternator - $125
Sr20det ac compressor - 80
Sr ac bracket - 45
Sr PS setup (everything needed) - $150
Speed sensor - $50
4x stock s14 rims - $110
350z oem carbon fiber drive shaft (manual) - 250
350z - transmission mount - $25 (used OEm)
350z trans bracket - $75
https://ibb.co/vhMVQr6
https://ibb.co/85fPmMC
https://ibb.co/12T6WCf
https://ibb.co/RcC0cf8
https://ibb.co/DpcBLJP
https://ibb.co/tqYrtkP
https://ibb.co/ZW5n5Dp
https://ibb.co/r3wRbbF
https://ibb.co/56rpGTn
https://ibb.co/0G6zdtD
https://ibb.co/cQ9wsfv
https://ibb.co/Hz4KPrh
https://ibb.co/kDqNDmw
https://ibb.co/cN5RMNq
https://ibb.co/w6pZnp9
https://ibb.co/1zXCTbr
https://ibb.co/f9t0bnZ
https://ibb.co/TRt82VJ
https://ibb.co/6PHwm9C
https://ibb.co/P5Qf6VR
https://ibb.co/r0XbJhx
More picture and parts coming soon!! Hmu
SidewayzAsFck is offline   Reply With Quote
Old 10-06-2020, 11:08 PM   #2
Big_MO
Big_MO is making a name for him/her selfBig_MO is making a name for him/her self
What year is the speed sensor from?
Big_MO is offline   Reply With Quote
Old 10-07-2020, 09:26 AM   #3
SidewayzAsFck
93 SR20det i believe
Old 10-07-2020, 10:23 AM   #4
itsmrgreen
itsmrgreen is an unknown quantity at this point
The oil pan fits in a s14? And the wire harness does it still have all the labels and will it work with a lq4?
itsmrgreen is offline   Reply With Quote
Old 10-07-2020, 10:23 AM   #5
itsmrgreen
Never mind on the harness just noticed RHD��
Old 10-07-2020, 09:08 PM   #6
SidewayzAsFck
It?s not for RHD, it was going to be extended for a RHD project but switched routes. It?s a brand new harness other than the interface harness being cut & labeled to be extended. It?s for a truck motor with LS1 acc, t56 trans, and MAP. The harness alone is $700 from WS. The interface harness is also interchangeable from s13/14 and usuales the same chassis harness connector main plug I believe
Old 10-08-2020, 04:25 AM   #7
itsmrgreen
How about the oil pan? Does it fit a s14?
Old 10-08-2020, 02:05 PM   #8
LLTSbs
LLTSbs is an unknown quantity at this point
PM sent for wheels
LLTSbs is offline   Reply With Quote
Old 10-10-2020, 07:26 AM   #9
SidewayzAsFck
Pan is rear sump, for our swap you need a front sump i think. It fits the engine but idk about clearance for s chassis
Old 10-12-2020, 06:10 AM   #10
Thursday7
Thursday7's Avatar
Pics of the RPS clutch? I'm only seeing an ACT disc and a SPEC disc & pressure plate.
WTB Bride Zieg II
Old 10-18-2020, 07:47 PM   #11
Thursday7
Thursday7's Avatar
Sent you a PM regarding the clutch(es)
WTB Bride Zieg II
Old 10-28-2020, 08:13 AM   #12
Thursday7
Thursday7's Avatar
Dood why post this stuff then disappear? Multiple PM's sent.
WTB Bride Zieg II
240 240sx s13 sr20, 350z, ls swap, wiring harness, wiring specialties
