Old 09-03-2010, 09:31 AM   #31
DenkiMan!
DenkiMan!'s Avatar
DenkiMan! is an unknown quantity at this point
this thread was actually rly helpful lol...ive been having the same problem with my 95 s14. that annoying kickback. the only suspension upgrades i have are kyb adjustable struts...came with car. i knew i needed a lsd tho, its good to understand why
but im looking to get a tomei 2 way soon!
Originally Posted by PSI240SX View Post
Although the 97 Maxima was aesthetical perfection, I thought the factory body lines could use some expert "tweaking" so I ran it into a couple of things at low speed.
Looking for another pair of 17x9 Veilside Andrew Racing V's
DenkiMan! is offline   Reply With Quote
Old 09-03-2010, 10:44 AM   #32
kuelee
kuelee's Avatar
kuelee is an unknown quantity at this point
This is correct. Ive tryed it before without lsd, and it snaps u back or like what your saying, oversteering. If u get a j30. i can almost guarantee it wont do that anymore.
Originally Posted by 5pecialist View Post
Unless I read your post wrong, it sounds like you need an LSD. Otherwise that snap back will always occur. Sure letting off the gas as suggested above will help somewhat, but you are really limiting yourself.
kuelee is offline   Reply With Quote
Old 09-04-2010, 09:55 PM   #33
Jonnie Fraz
Jonnie Fraz's Avatar
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Send a message via AIM to Jonnie Fraz
Like tons of others have told you it is the diff. Welded to start, have someone who knows what they are doing weld your diff please! When you can afford it look at getting a two way. You can learn allot with just a welded dif. Look at going to a local sponsored track/ skid pad event. You will learn more that day than you will all year in a parking lot. Use your money to upgrade suspension buy track time and buy tires. Always suspension before power!
Now for my little service announcement...Several guys with way more experience than you have tried to help, and you have spit in their face. I have run across a couple of kids like you...one has destroyed seven perfectly good 240's because he will not listen. He has been very lucky that he has not hurt or killed anyone. Do you see where I am going?
Good luck with your quest, and I hope to see you at the track someday.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 09-21-2010, 11:18 AM   #34
jdhariwal
jdhariwal's Avatar
jdhariwal is an unknown quantity at this point
LOL, this thread took a turn for the worse pretty quick.
jdhariwal is offline   Reply With Quote
Old 09-23-2010, 02:11 PM   #35
GoNissanGo
GoNissanGo is an unknown quantity at this point
Damn guys he's a noob and just got hurt feelings. We dont have to be that mean ;-) That said... shut up and take their advice... ie listen to that guy thats an instructor! Can you really argue with someone thats knows that much...
maybe your name should be "little curb hopper" Damn I got mean too. Pherhaps this guy understands now.. Dont screw with people trying to help...
Take it as a lesson don't get jaded just be more open to advice.
GoNissanGo is offline   Reply With Quote
Old 09-23-2010, 06:55 PM   #36
javedjee77
javedjee77 is an unknown quantity at this point
On some of the forums I've been on I've seen this or something similar, it turns into a mess and becomes a vendor war that always ends up ugly.
javedjee77 is offline   Reply With Quote
Old 09-24-2010, 11:07 AM   #37
Peter89#2
Peter89#2's Avatar
Peter89#2 is an unknown quantity at this point
weld it. should cost less then $50.
Peter89#2 is offline   Reply With Quote
Old 09-24-2010, 11:28 AM   #38
dsastr_clan
dsastr_clan is an unknown quantity at this point
try a different setting on ur coilovers, i had megan tracks too not bad for a beginner i will suggest you to go full hard on the rear and full soft on the fronts and change the front camber to negative.
dsastr_clan is offline   Reply With Quote
Old 09-24-2010, 03:21 PM   #39
fckillerbee
fckillerbee's Avatar
^^^clearly cause both of your cars are exactly the same.
Old 09-24-2010, 04:17 PM   #40
dsastr_clan
my he can experiment with that see if it works.
Old 09-24-2010, 04:30 PM   #41
fckillerbee
i understand your input...but from my experience....
the driver, the car, and the parts, make every scenario different. everyone in here can make recommendations....he is the only one that will know what works....
the best bet....is taking it to an event where a instructor can properly evaluate what you have, and what you need.
any other info isn't necessary until he does so...and any other questions are unecessary until so. ;D
Old 09-27-2010, 10:52 AM   #42
angelus erratus
angelus erratus is an unknown quantity at this point
join roadster drift, they have a porn thread, i can call my friends Caucasian, Mongoloids, Negroids and not get banned, and the assholes are much better at being assholes.
KITTY GATO POWA!!!
angelus erratus is offline   Reply With Quote
Old 09-27-2010, 10:59 AM   #43
angelus erratus
if you want gangster ass over steer, get rid of your front sway bar, get matched spring rates...
KITTY GATO POWA!!!
Old 09-28-2010, 02:51 PM   #44
fckillerbee
removing the front sway bar and getting the same set of springs all the way around would be as if keeping the car the same...sway bar prevents roll, and matching springs prevent roll, so you are throwing one away to pick up the other...any video of this tested out? i'd like to see why you recommended this.
Old 09-28-2010, 08:22 PM   #45
angelus erratus
what would happen if an inexperienced driver got matched spring rates, and a thick rear sway bar? i am just curious, cuz i don't know shit home boiii, i was raised by a pack a wolves, and all i know how to do is skeet skeet.
KITTY GATO POWA!!!
Old 09-29-2010, 02:41 PM   #46
fckillerbee
rear sway bars induce oversteer....that's what would happen. lmao....haha skeeter
Old 09-29-2010, 09:34 PM   #47
angelus erratus
hahaha, wtf, making me feel old because i actually remember watching this as a kid .
KITTY GATO POWA!!!
32 way, bandwagoner, drifting, megan track coilovers, oversteer, stupid noob, transition
