Old 06-14-2005, 09:14 AM   #1
24Dee
24Dee is making a name for him/her self24Dee is making a name for him/her self
anyone have pictures of...
...beam patterns on an s14 with the German headlight housings and halogen bulbs in them?
The few things that I found through searching were HID kits in them.
I remembering seeing pictures awhile back of an aftermarket headlight housing with halogen bulbs in them and the beam pattern was horrid. I think they were the Final Konnexion lenses though, not fully sure.
24Dee is offline   Reply With Quote
Old 06-14-2005, 09:31 AM   #2
MrSkinny
MrSkinny is an unknown quantity at this point
german are the same as what u have in your NA car. just that its glass instead of plastic. theyre still fluted. as far as i know fk are the only ones that make a clear one but those are useless unless uhave HIDs. google systemQ s they carry them..
MrSkinny is offline   Reply With Quote
Old 06-14-2005, 10:28 AM   #3
hotrodv
hotrodv's Avatar
hotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfection
Isn't German..I think all the european S14 have clear lens..
hotrodv is offline   Reply With Quote
Old 06-14-2005, 01:38 PM   #4
projectRDM
projectRDM's Avatar
All Euro S14s have glass lens. But not all are LHD.
The LHD glass beam pattern is nearly identical to the US (when new and not yellowed), the main benefit is individually adjustable beams. The US reflector is one piece, the Euro is two piece allowing for separate aiming of low and high beams. That was the most noticeable improvement for me. The next enhancement is implementing the UK electric aiming switch, mine's finished but I haven't driven the car yet to play with it. This allows you to set the low beams a little below optimal (good for HID use, since it cuts off higher) and then raise it from inside for darker roads. That leaves the highbeams set where they need to be and doesn't screw up the aiming like the US lights do.
FORMERLY R240NA
Old 06-14-2005, 01:45 PM   #5
24Dee
So the German (Euro) headlights that Courtesy sells are just LHD glass versions of the ones we have here in the US? Eventhough they are glass, they get that yellow tint too?
I was under the impression that having the glass housings would somehow improve the output and beam pattern. Also eliminating that yellowish tint.
Old 06-14-2005, 06:25 PM   #6
projectRDM
projectRDM's Avatar
No, you read wrong. Glass does not yellow.
The beam pattern is near identical to the US lights IF they're new and not yellowed. I put my Ecode lights on only eight months after replacing the US lights, so they hadn't yellowed yet. Virtually no difference from inside the car other than the ability to aim better.
Courtesy's are true Euro lights, there's just a lot of LHD countries overseas.
FORMERLY R240NA
Old 06-14-2005, 08:12 PM   #7
S_14.5
S_14.5's Avatar
S_14.5 is an unknown quantity at this point
Bad pattern b/c they were Japanese S14 Zenki headlamps for RHD.
S_14.5 is offline   Reply With Quote
Old 06-15-2005, 06:40 AM   #8
24Dee
I understand what you mean but I meant bad as in the light output was all over the place. There wasn't one point of focus at all... it was just light scattered everywhere.
