Old 02-06-2012, 12:48 PM   #1
RandallSharp
RandallSharp's Avatar
RandallSharp is an unknown quantity at this point
What sensor is this???
I have a 91 Base that was auto to manual swapped 2 owners ago. The guy I got it from had no idea what it was and neither do I. Can someone please tell me what this is?
Info on it:
The metal part is magnetic
It has "AG" on one side and "009 RS-104" on another.
It has one hole for a mounting bolt/bracket I believe.
It looks like it goes into a small harness which then goes to the fuse block by the battery
Here is the sensor:
Here's the little harness I think it goes into:
The only light on my dash is the cat overheat (windshield wiper low on usdm) light. No idea why either because I just topped that off!
Any info is appreciated, thanks guys.
1991 240sx Hatch Daily'd!
RandallSharp is offline   Reply With Quote
Old 02-06-2012, 01:05 PM   #2
freeagent3117
freeagent3117's Avatar
freeagent3117 is an unknown quantity at this point
if it was a auto then its gotta be a sensor off that. prob either a reverse or park sensor. is it attached to any of the tranny harness?
freeagent3117 is offline   Reply With Quote
Old 02-06-2012, 01:47 PM   #3
RandallSharp
That's what I was figuring. As far as I can tell, it just goes into the harness conduit and straight to the gray plug block/fuse block I pictured. I can check it out better a little later if that would help. My reverse lights do not work though.
Old 02-06-2012, 02:35 PM   #4
freeagent3117
heres the place to goto to get your reverse lights working.
How To: 5 Speed Swap in Convertibles (and other S13s) : 240SX Convertible Forum
Old 02-06-2012, 03:33 PM   #5
RandallSharp
Okay, cool. I'll check that out later when I have a computer. So no idea on the sensor then?
Old 02-06-2012, 03:58 PM   #6
freeagent3117
all the sensors from the tranny go into the block. there is three sensors on the tranny. reverse sensor, park sensor, and speed sensor. guessing the fact your speedo works, its one of the two for sure.
Old 02-06-2012, 04:02 PM   #7
freeagent3117
oh and is that a nasty fram oil filter i see?!
Old 02-06-2012, 04:07 PM   #8
thinhthan
thinhthan is an unknown quantity at this point
i had the same sensor on my 95 when i did the conversion. i just cutted it and i pulled all the other inhibitor switch wires out. speedo and everything still works
thinhthan is offline   Reply With Quote
Old 02-06-2012, 04:23 PM   #9
RandallSharp
Alright then, I appreciate it.
Just got this car, I haven't had a chance to change the oil. Wix only for me
Hmm, I want someone to confirm what it is before I chop it out, but thanks for the input.
Old 02-06-2012, 04:59 PM   #10
Eramo323
Eramo323 is an unknown quantity at this point
Send a message via AIM to Eramo323
weird i have never seen that sensor and ive helped out with a few 5 speed swaps
Eramo323 is offline   Reply With Quote
Old 02-06-2012, 05:10 PM   #11
RandallSharp
Well it may not have anything to do with the transmission or swap, I just don't know what it is period. I guess it's possible they were trying something custom, but that's unlikely.
