Old 07-18-2010, 06:38 PM   #1
kanekoa28
kanekoa28's Avatar
kanekoa28 is an unknown quantity at this point
Timing chain rattle or lifter tick?
So I bought a new timing chain kit for my 95 s14 installed it (PITA) then started the engine and I got a horrible knocking/rattle sound.
Yes I have searched around for the answer but I wanted to get more opinions on this before I rip the front cover off again.
Im pretty sure its not knock because I pulled each spark plug and nothing changes. Before I did the install the noise wasn't there either. I also read about the famous chain rattle so I took out the 2 guides everyone says to take out and still the same.
Like i said just wanted some opinions if any of you guys did the timing chain you know its a PITA to do.
lmk wat you think
mahalo
&fs=1" width="644" height="390">http://www.youtube.com/watch?v=<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/ZrYgX7DEDAk&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ZrYgX7DEDAk&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
kanekoa28 is offline   Reply With Quote
Old 07-18-2010, 06:51 PM   #2
jamanrr
jamanrr's Avatar
jamanrr is an unknown quantity at this point
sounds like a normal truck engined KA to me.
jamanrr is offline   Reply With Quote
Old 07-18-2010, 07:55 PM   #3
kanekoa28
kanekoa28's Avatar
haha serious???
Old 07-18-2010, 08:07 PM   #4
jamanrr
jamanrr's Avatar
Originally Posted by kanekoa28 View Post
haha serious???
Yeah I had a auto KA before I swapped over to my SR and it had timing chain rattle. I hear none of that in your vid and it sounds pretty normal to me. Some other peps might chime in but I have heard dozens and dozens of KA powered 240s.
Old 07-19-2010, 04:34 PM   #5
kanekoa28
kanekoa28's Avatar
Guess no one else got any opinions
Old 07-19-2010, 05:15 PM   #6
[email protected]
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
thats definitely not normal!
R@ddy is offline   Reply With Quote
Old 07-19-2010, 05:18 PM   #7
jserman
jserman's Avatar
jserman is an unknown quantity at this point
I didn't think the dohc had the guide issues.... I had a timing chain noise and I have had stuck lifters and neither sounded like that....
you sure your timing isn't off???
the only reason I say this cause if it wasn't there before then that might be the issue if you changed out the timing chain
jserman is offline   Reply With Quote
Old 07-20-2010, 08:48 PM   #8
c-los13
c-los13's Avatar
c-los13 is an unknown quantity at this point
WOW
i thought mine was loud
try switching the oil to 20-50w
thats what most of my 240 friends do
wish i could help more but mine is kinda loud too
DONT TRY SEAFOAMING IT! my friends engine broke like that!
c-los13 is offline   Reply With Quote
Old 07-21-2010, 01:28 AM   #9
Sam_Well.13
Sam_Well.13 is an unknown quantity at this point
Originally Posted by c-los13 View Post
WOW
really? did he do it wrong or something? im bout to do that to my coupe,
but i seafoam my 89 benz carburetor and it idles smooth and runs soooo smooth after.. but ofcourse i included a full tune other than jst your regular oil change..
to the OP, that definitely doesnt sound right, i have a very very very minor ticking on. havent had time do really check mine out, but hope you get yours fix...
Sam_Well.13 is offline   Reply With Quote
Old 07-21-2010, 06:26 AM   #10
kanekoa28
kanekoa28's Avatar
thanks for the replys guys.
Ive read while searching that thicker oil sometimes help but to be careful not to go to thick. and Ill double check on the timming as well
Old 07-22-2010, 12:28 PM   #11
miravete
miravete's Avatar
Trader Rating: (44)
miravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant futuremiravete has a brilliant future
Feedback Score: 44 reviews
you removed the guides, but did you replace the tensioners?
the little piston that pushes the tensioners are what get stuck.
replace those, and you should be good to go.
taking corners just as good as a drunken rhino..
miravete is offline   Reply With Quote
Old 07-22-2010, 12:46 PM   #12
druthafoo
druthafoo's Avatar
druthafoo is an unknown quantity at this point
I literally just did this last night. Make sure those tensioners are nice and clean. My ka will now last me another 100K aha.
***PM for Stereo Help***
Eclipse55090CrystalSSCS6SIMAG
druthafoo is offline   Reply With Quote
Old 07-23-2010, 09:57 AM   #13
kanekoa28
kanekoa28's Avatar
yes i did change the tensioners I wonder if the new one could possibly be stuck
Old 07-23-2010, 11:03 AM   #14
miravete
miravete's Avatar
Trader Rating: (44)
if they get stuck, then it must be the money, am, em, i mean the oil lol
must be the oil that its too thick, or too dirty.
Old 07-23-2010, 11:04 AM   #15
miravete
miravete's Avatar
Trader Rating: (44)
i finally saw your vid, and it sounded exactly like mine.
i changed out the bottom piston tensioner, and removed the guides, and all was good after that
Old 07-23-2010, 09:27 PM   #16
kanekoa28
kanekoa28's Avatar
well probably gonna rip it back down and check the lower tensioner to see if its stuck or not. The one you changed was it the one that can be reached by just taking off the top cover?
Old 07-23-2010, 10:27 PM   #17
saleaf
saleaf's Avatar
saleaf is an unknown quantity at this point
Sounds like fun to me..... Im still waiting for my KA to pop so i can go get a RB
saleaf is offline   Reply With Quote
