![]() Join Date: Jul 2009
![]() Feedback Score: 27 reviews
GodSpeed TD05 18G and TD06 20G Bottom Mount Turbo (Direct Bolt On)
Godspeed TD05 18G and TD06 20 Bottom Mount Turbo Both Driect Bolt on SR20 Redtop and Blacktop TD05 18G on the Left and TD06 20G on the Right TD05 18G TD05 18G Turbo Spec. Bearing system: Journal Bearing Compressor Wheel Diameter: 50.3 / 68mm TURBINE Wheel Diameter: 49.2 / 56mm Turbine TRIM: 57 Turbine flange type flange: T25 Downpipe flange type : 240sx 5 bolt type Nozzle Area: 8cm² Cooling type : oil and water cooled. Horsepower rating: 300-380 hp BOLT ON TURBO FOR S13 S14 S15 (SR20 MOTOR) Actuator set at : 14.5 PSI CFM: 600 Mod on our Time Attack 240SX, SR20 Redtop Stock with HKS CAM, Godspeed Intake Manifold , Turbo Manifold , Turbo Back Exhuast , Stock Piston and Rods YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 1st Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 2nd Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 3rd Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 4thd Pull more info. please check http://zilvia.net/f/tech-talk/323337...dyno-test.html TD06 20G This is on a Black top S14 with 650cc injector , stock internal and 14.5 psi. TD06 20G Turbo Spec. Bearing system: Journal Bearing Compressor Wheel Diameter: 58.8 / 68mm TURBINE Wheel Diameter: 58.8 / 67.14mm Turbine TRIM: 57 Turbine flange type flange: T25 Downpipe flange type : 240sx 5 bolt type Nozzle Area: 8cm² Cooling type : oil and water cooled. Horsepower rating: 400-450 hp BOLT ON TURBO FOR S13 S14 S15 (SR20 MOTOR) Actuator set at : 14.5 PSI CFM: 640 No Restrictor need for oil feed line TD05 18G $330 Shipped (Lower 48 State) $362.17 Shipped/Taxed (CA Customer) $310 Pick Up Preferred Cash TD06 20G (In Stock!!!! $450 Shipped (Lower 48 State) $493.87 Shipped/Taxed (CA Customer) $430 Pick Up Preferred Cash Please PM for Payment Method. Fatboy Garage Motorsport Inc GODSPEED Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 ask for Ken W:godspeedproject.com Last edited by Fatboy Garage; 04-18-2011 at 12:34 PM.. |
It's Always Broken.
![]() Join Date: Feb 2010
In regards to the TD06 20G...will it bolt up to a KA-T bottom mount T25 manifold without clearance issues? Also, does it use the standard SR turbo elbow?
Also, is that actuator adjustable..? Looks like it.
![]() Join Date: Nov 2007
![]() ![]() ![]() Feedback Score: 27 reviews
Will there be any fitment issues with the 20g on an sr20 swap. I cant wait till you guys mount this to one of your guys track cars. Please let us know how the fitment is. Does it hit the motor mount?
BX|Photo LS400 - Slammed | Fitted | Loud |
So your saying the factory inlet and outlet of my t28 will not bolt up? Or are these clocked differently?
#12 | |
Thanks Ken,S |
#15 | |
no is not ok to run it without water, turbo will not cover by warranty.
Thanks Ken,S |
#21 |
Price on a package deal of
Turbo Manifold (t25 bottom mount) Turbo Elbow (Screamer) tdo5-18g turbo shipped to 89031 please thanks
#25 |
![]() Join Date: Jan 2008
any updates on on the time attack 240 running the new 20g?
..has anyone else installed the 18g?? i have mine sitting on my room. im still gathering few more parts till i put it in and im curious to how the setup is with anyone else?! |
#28 |
need advise on TD06
About two years ago I bot a Greddy kit to turbo my ka motor with 150lbs compression on all four cyl and it ran great until last month when it blew rings in #2. dyno pulled [email protected] Bot a red top SR and have all the Greddy bits. now the questions:
1. can I run the td06-20g on the SR. 2. how big of injectors should I run? Now 370s 3. can I use the e-manage system? will it have to be reprogrammed? 4. How much more power could I expect over stock running at 8-10lbs boost? 5. Whats the best manifold to get? current set up 3 " exhaust FMIC TD06-20g 370s fuel rail walpro fuelpump ![]() z32 maf emanage |
#30 |
Banned from the Marketplace
![]() Join Date: Dec 2006
heres my experience bolting the 18g up
stock oil line does not bolt in oil drain does not go towards the block had to mod oem t25 drain to fit turbo screamer pipe wont bolt up due to tiny divider in exhaust housing heres a crappy picture of it bolted onto the motor motor is going into car soon ![]() |
