Old 05-23-2005, 10:14 AM   #1
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
Erattic fuel pressure
I have a 98 blacktop S13 SR running a JGS fuel rail 560cc top feed injectors, walboro 255 pump, and a nismo adjustable FPR i have it set to 44psi but when it warms up or under load i am not getting consistant pressure i have sen it drop as low as 12 about 5 lbs of boost at full throttle when running and it seems to fluctuate between 20 and 35 psi during light throttle and idle not sure what is up with it
btw I am using a new 300zx fuel filter and it is controlled by a haltech ecu
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 05-23-2005, 01:44 PM   #2
orion::S14
orion::S14's Avatar
orion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to behold
Do you have the OEM wiring goig to the pump, or a seperate circuit with new relay? S13 wiring is known to be insufficient for bigger pumps.
If it's just stock wiring...run a new ciurcuit to the fuel pump.
Use the stock fuel pump + wire to turn a relay on and provide a dedicated circuit just for the pump.
See KA-T.org for a S14 install...S13 is almost identical:
http://www.ka-t.org/tech - "Rewiring Your Walbro 255 Pump for S14's"
Do that, report back with results...
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 05-23-2005, 01:52 PM   #3
the head
the head's Avatar
Good thought I will just hotwire the pump 10 ga sould be sufficent for the power wire right?
Old 05-23-2005, 02:57 PM   #4
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
don't hotwire it, a relay cost's like $4.
RBS14 is offline   Reply With Quote
Old 05-23-2005, 04:06 PM   #5
the head
the head's Avatar
That is how it is referred to where i am from if you are mainlining power to the pump we call it hotwiring with or without the relay
I am using a relay
Old 05-23-2005, 05:01 PM   #6
RBS14
RBS14's Avatar
oh ok, cool.
