Old 02-24-2009, 11:21 AM   #1
kalypso123
(ノಠ益ಠ)ノ彡
Koni yellows and GC sleeves... how?
how do you build a set of coils for an s13 with these...
and furthermore how do you attach them to a hub assembly.
someone please cure me of my ignorance.
pics or diagrams would help a lot.
Old 02-24-2009, 11:33 AM   #2
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
You have to cut your existing front struts and gut them out. Then drill a hole in the bottom. The koni damper drops in and you bolt it in with the hole you drilled at the bottom of your gutted old strut housing. You also have to cut the spring seat off the housing and figure out a way to mount the GC sleeve to it.
The rears just bolt on like any damper/spring assembly.
Chernobyl is offline   Reply With Quote
Old 02-24-2009, 10:43 PM   #3
kalypso123
(ノಠ益ಠ)ノ彡
thank you...
- GC sleeves, whats GC is an abbreviation for. im searching for them on google but i havent found a place that sells them.
- Lasly... with the sleeves can these get as low... as a standard set of coils? any limits on height?
thank you for your help. threads about this, are by people who already know what they're doing.
Old 02-24-2009, 10:52 PM   #4
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
GC = ground control
there's a couple of threads with plenty of info in them
Old 02-24-2009, 10:55 PM   #5
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
*sigh* i remember having ground controls 10 years ago. i'm getting old!
kensreliableb18b is offline   Reply With Quote
Old 02-25-2009, 05:06 AM   #6
kalypso123
(ノಠ益ಠ)ノ彡
much appreciated
Old 02-25-2009, 09:29 AM   #7
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
A member on here could make you brand new seats for the fronts.
http://zilvia.net/f/tech-talk/161773...ion-worth.html
SochBAT is offline   Reply With Quote
