Old 10-04-2012, 11:39 PM   #1
marryson
marryson is an unknown quantity at this point
Covering the air filter slightly with a plastic bag to pass emission test
I just came up with this crazy idea..... my car keeps failing NOx which is caused by running to lean. (too much air, too little fuel). If i cover the airfilter slightly with a plastic bag, restricting the amount of air going into the engine. thus making the car run richer. and hopefully reduce the NOx reading. What do u guys think? will it work? what are the dangers?
marryson is offline   Reply With Quote
Old 10-04-2012, 11:43 PM   #2
jesse_s13
jesse_s13's Avatar
jesse_s13 is an unknown quantity at this point
jesse_s13 is offline   Reply With Quote
Old 10-04-2012, 11:45 PM   #3
marryson
Originally Posted by jesse_s13 View Post
Just told my friend about this shit. same reaction lol is correct..... but in theory I dont see why it wouldnt work
Old 10-05-2012, 06:18 AM   #4
Croustibat
Croustibat is an unknown quantity at this point
because your ECU measures air that enters and computes how much fuel it needs to send based on its mapping ... you are not running an alpha-N management system that computes how much fuel it has to send depending on the throttle position.
You are failing emissions because your car has a problem, most common MAF system related problem is boost leak, coated MAF, dead lambda sensor, dead temp sensor, worn engine ... or just dead cat.
Croustibat is offline   Reply With Quote
Old 10-05-2012, 08:58 AM   #5
satek
satek's Avatar
satek is an unknown quantity at this point
Retard your timing...worked for me.
satek is offline   Reply With Quote
Old 10-05-2012, 10:32 AM   #6
project-c2
project-c2 is an unknown quantity at this point
Adjustable fpr?
project-c2 is offline   Reply With Quote
Old 10-05-2012, 10:49 AM   #7
marryson
Originally Posted by project-c2 View Post
Adjustable fpr?
whats fpr?
Old 10-05-2012, 11:17 AM   #8
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
Fuel pressure regulator.
Frank_Jaeger is offline   Reply With Quote
Old 10-05-2012, 01:48 PM   #9
marryson
I dont think mine is adjustable... but I passed the test today after running seafoam thru brake vacuum and intake. reduced nox by about 15%. I also changed the fuel filter too. and no i did not use a plastic bag to cover the filter lol
