Old 10-04-2009, 09:56 PM   #1
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
Exclamation Help !!! Im running on 3 cylinders !!
Ok well I turned my s13 with a s14 ka on and then i started noticing a rough idle. So with the car still on... i pulled one of my spark plug wires of #1 was fine then #2 was fine. Then #3 didnt do anything. #4 was fine. so I thought it was time for some new spark plugs. but even with the new plugs its the same thing. Im guessing its the wires? but it could be something else. there has to be a reason why its #3. So Isearched allover and no one has any info on this so can I please get some knowledge to what you may think is the most obvious problem? thanks
jdm213 is offline   Reply With Quote
Old 10-04-2009, 10:40 PM   #2
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
get new plug wires
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 10-04-2009, 10:43 PM   #3
gotspins13
gotspins13's Avatar
gotspins13 is an unknown quantity at this point
Send a message via Yahoo to gotspins13
dead injector.
not getting spark.
spark plug is shit.
thats all i can think of right now, soo get to work and start crossing off that list.
goood luckkk
perfectly said! FJ20ET 16 valve - the holy grail of Nissan engines
gotspins13 is offline   Reply With Quote
Old 10-05-2009, 07:32 AM   #4
projectRDM
projectRDM's Avatar
Swap the wires between that cylinder and another. If it's still dead, it's the injector.
FORMERLY R240NA
Old 10-05-2009, 02:00 PM   #5
jdm213
jdm213's Avatar
Thanks guys i will definatly check this out, I just want to make sure and yeah im probably going to get some new injectors but ima check this out. By the way can I use 370cc fuel injectors from a sr20det with a n/a ka? I think not though but hmm its a good question?
Old 10-05-2009, 02:22 PM   #6
projectRDM
projectRDM's Avatar
Search. Well beaten question. Short answer is no, and you should be smart enough to know why without asking, but if not, go find out.
FORMERLY R240NA
Old 10-10-2009, 02:14 PM   #7
jdm213
jdm213's Avatar
ok well i got new injectors and still the same so i think it could be the distributor cap, or rotor, or wires so ima see this today.
Old 10-10-2009, 08:27 PM   #8
jdm213
jdm213's Avatar
ok I tried the new ditributor cap, new rotor, spark plugs and wires and it still idling wierd. I also changed the injector and its the same thing. when I pull the spark plug wires off it shakes so i know they work. but when i pull the 3rd one it soesent do anything and I tried all those things and nada, same thing. So does anyone have any input on this, I really need your help? Please and thank you =/
Old 10-10-2009, 08:51 PM   #9
P_856
P_856's Avatar
P_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really nice
i had the same problem i was going to swap the engine so i reved the shit out of it and then everything worked again weird right lol
P_856 is offline   Reply With Quote
Old 10-11-2009, 12:49 PM   #10
jdm213
jdm213's Avatar
PLEASE HELP !!!! THIS A SERIOUS ISSUE I DONT KNOW WHAT ELSE TO DO
Old 10-11-2009, 01:09 PM   #11
240sxxs
240sxxs's Avatar
240sxxs is an unknown quantity at this point
maybe try and rev the "SHIT" out the engine and it might work !!..sory i never come across this problem..but i hated most of the problem that come from the "cross off list" catergories
The pretty one Arn't free and the free one Arn't pretty
240sxxs is offline   Reply With Quote
Old 10-11-2009, 04:26 PM   #12
!Zar!
!Zar!'s Avatar
Did you lube the injectors when you installed them?
Check your spark plug wire order. All the engine needs is air, fuel and spark. If you changed the injectors and wiring/plugs properly, all that's left is air. So unless you dropped a valve or something, there is no reason why it shouldn't be working theoretically.
Did your engine overheat? Or were you driving it harder than average when this problem occurred?
Old 10-11-2009, 06:41 PM   #13
jdm213
jdm213's Avatar
No it hasnt overheated and i havent driven it hard, I just turned it on one day and it srated idling rough. i dont know if its the 3rd valve but i know this is going to get expensive =/ what do you think I should do?
Old 10-11-2009, 06:59 PM   #14
andres13
andres13's Avatar
andres13 is an unknown quantity at this point
i have the same problem i put new injector and work perfect check your injector before just get one and try if the work
andres13 is offline   Reply With Quote
Old 10-11-2009, 08:57 PM   #15
jdm213
jdm213's Avatar
ok ill try it probably i didnt put them right but i checked the injector cables with a noid light and they all work. when i pull all the inj cables out the car studders except the 3rd one so it may have to do something with the 3rd injector ima take it out and check it and put it back on. thanks for your help. keep the answers coming. thnks
Old 10-13-2009, 02:25 PM   #16
jdm213
jdm213's Avatar
well i found out the problem... The new injector i bought was defective so I had to get a used one from another 240sx and BAM! it works. So right now im cleaning the fuel injectors with the injector cleaner and cleaning the system with sea foam. Thanks guys for all your help
