Old 02-07-2013, 02:33 PM   #1
Newsboys
Newsboys is an unknown quantity at this point
P0705 in a factory s14 5spd??
This is slightly weird, Im 100% sure that a PRNDL code is for a auto not a manual. Yes, im certain its 5spd its whole life I contacted a Nissan dealer gave em my vin and it came as a 5spd. So wth is with the prndl code? Anyone had this before?
Newsboys is offline   Reply With Quote
Old 05-25-2013, 12:55 PM   #2
w0lfatncsu
w0lfatncsu is an unknown quantity at this point
Wish I had seen this sooner. It's your neutral switch on a manual car. The neutral switch is on the transmission in front of the shifter on the right side. Check the connector harness to the switch and double check at the ecu as well. The procedure is in the FSM.
w0lfatncsu is offline   Reply With Quote
