Old 01-08-2012, 05:18 PM   #1
MurkyRiversS13
MurkyRiversS13's Avatar
MurkyRiversS13 is an unknown quantity at this point
S13 & KA24DE parts that'll make you smile :)
I have quite a few parts that have some how found a way into my garage and I need the space more than they do.
PM me for anything you may want or any questions you may have, I am willing to ship most items at the buyers expense.
Washer Fluid Container with motor and level senor: SOLD
Stock Header with heat shield and downpipe: SOLD
Whatever the hell this thing is lol: $10
Perfect Condition OEM alternator (bought this as an extra) $30
Ka24de Fuel rail with regulator: $20
ka24de stock injectors: $20
SR 370cc injectors new pintle caps and filter (2 work perfectly, 2 stopped working for me so Im not sure what the problem is): $40
OEM radio brackets: SOLD
Dash Center Vents:All Sold
Driver side door handle garnish: $FREE with anything you buy if you want it
Speaker/amp wiring and fuse thingy......: SOLD
AC components from engine bay..... everything including compressor: SOLD
Stock fan with shitty clutch: $5
OEM Distributor cover: $10
Headlight, turn signal switch: SOLD
ka24de Gauge cluster with harness and surround not in the greatest condition but better than most, gauge cluster is missing the clear plastic cover: SOLD
OEM ebrake cover: SOLD
OEM steering wheel, the squishy one, the top is a little loose but its not too bad: $10
Center vent duct: $2 free or going in the trash
Some random shift knob, a little heavy but not as heavy as stock: $10
Silvia triple projectors, lenses perfect, broken tab on the right one, left one is perfect, no wiring harness or covers. Ill include an HID kit for the lows: SOLD
Cracked Dash, better than most, but worse than a lot: $15
EGR valve and tube: SOLD
Stock SR intercooler with BOV and all piping even an extra cold pipe, bought a FMIC so no need for this: SOLD
EGR and SCV solenoids with mounting plate: SOLD
KA24DE perfect condition wiring harness and ECU for 5speed: SOLD
KA24DE turbo manifold for SR T25, has cracks, is repairable but I just bought a different one instead of dealing with this one: SOLD
S13 open dif and output shafts: $20
J30 dif case with cover: $20
MurkyRiversS13 is offline   Reply With Quote
Old 01-08-2012, 05:26 PM   #2
mike cm
mike cm is an unknown quantity at this point
Hmmm pm me on the manifold shipped to 02148 please and thank you.
Also pictures of said cracks and what material is the manifold?
mike cm is offline   Reply With Quote
Old 01-08-2012, 06:22 PM   #3
crazi86
crazi86 is an unknown quantity at this point
I'll take the headlight switch
crazi86 is offline   Reply With Quote
Old 01-08-2012, 06:31 PM   #4
90240sx07
90240sx07 is an unknown quantity at this point
willing to split the harness and ecu up?
90240sx07 is offline   Reply With Quote
Old 01-08-2012, 06:34 PM   #5
seeninjapan
seeninjapan is an unknown quantity at this point
is the Washer Fluid Container off a s13 or s14?
if its off a s14 then i need it, and my zip code is 80003, let me know what shipping will be.
thanks
seeninjapan is offline   Reply With Quote
Old 01-08-2012, 06:53 PM   #6
zombiewolf513
I need a KA temp sensor
I also need the adjustment bolts for the idler puller.
Any dice?
Old 01-08-2012, 06:54 PM   #7
crazi86
And is ac for dual cam?
Old 01-08-2012, 07:12 PM   #8
MurkyRiversS13
Ill get pics tomorrow. The cracks are in between the #3 #4 runners, you can see where it was attempted to be fixed.
Let me know how you want to get it.
If I have a buyer for the ECU and a buyer for the harness then I will split them up.
thanks
Sorry, this is off an S13
Any dice?
Sorry, no temp sensor or adjustment bolt..... well the adjustment bolt is part of all the AC shit thats for sale...... so..... yeah lol.
AC is for dual cam S13, Im not sure if its compatible with any other chassis.
Old 01-09-2012, 10:14 AM   #9
MurkyRiversS13
Bump..... $20 bucks off anything over $100
Old 01-09-2012, 04:15 PM   #10
Rymel
Rymel is an unknown quantity at this point
Send a message via AIM to Rymel Send a message via MSN to Rymel Send a message via Yahoo to Rymel
interested in:
-washer fluid container setup
-a/c setup only if it's actually complete and can figure out how to ship it without damaging the aluminum hardlines in transit
price quote to 10305. thanks in advance.
Rymel is offline   Reply With Quote
Old 01-09-2012, 04:52 PM   #11
tre4s13
tre4s13 is an unknown quantity at this point
Send a message via AIM to tre4s13 Send a message via Yahoo to tre4s13
dizzy cover and kat header to 27103
pm me
tre4s13 is offline   Reply With Quote
Old 01-09-2012, 05:35 PM   #12
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
Do you have a dual cam cluster sub harness? How much for it shipped to Norcal 94579?
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 01-09-2012, 07:00 PM   #13
MurkyRiversS13
Originally Posted by Rymel View Post
interested in:
AC setup is pending sale for Friday, if it doesnt go Ill look into arranging shipping. I have a shipping department in my company so I should be able to get quotes tomorrow. I would assume the washer fluid container would be 30 shipped.
pm me
PM sent
Are you asking about the harness that connects the cluster to the dash harness? the one pictured?
Old 01-10-2012, 10:42 AM   #14
Mitsubayati
Trader Rating: (18)
I couldn't tell if that was the harness, but yes, the one that connects the cluster to the dash harness. I have a single cam harness and cluster with a dual cam motor, so I need to be able to convert it. Is that what I need? I already have a dual cam cluster.
Old 01-10-2012, 11:39 AM   #15
khon240sx
khon240sx's Avatar
khon240sx is an unknown quantity at this point
cluster with harness shipped to 19082?
khon240sx is offline   Reply With Quote
Old 01-10-2012, 01:19 PM   #16
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
Originally Posted by MurkyRiversS13 View Post
[B][COLOR="SeaGreen"][SIZE="4"]
Stock SR intercooler with BOV and all piping even an extra cold pipe, bought a FMIC so no need for this: $75
still have this?? pm me pls
tapdeznutz is offline   Reply With Quote
Old 01-10-2012, 10:03 PM   #17
holslut s13
holslut s13's Avatar
holslut s13 is an unknown quantity at this point
PM'ed about exh mani!
holslut s13 is offline   Reply With Quote
Old 01-10-2012, 10:14 PM   #18
90S13hatch_tony
90S13hatch_tony's Avatar
Trader Rating: (24)
90S13hatch_tony is an unknown quantity at this point
Feedback Score: 24 reviews
You have a pm sir!!
90S13hatch_tony is offline   Reply With Quote
Old 01-10-2012, 10:17 PM   #19
MurkyRiversS13
^ you have a response sir
Old 01-11-2012, 04:22 PM   #20
Rymel
got an a/c setup from another seller, but thanks. however if washer reservoir isn't sold yet, pm me. i'll take it.
Old 01-11-2012, 07:16 PM   #21
MurkyRiversS13
Updated, some items sold and some prices reduced.
I need space for my teletubby collection and this stuff is delaying that. Get it out of my garage
Old 01-13-2012, 10:16 PM   #22
MurkyRiversS13
Last bump.
Old 01-19-2012, 11:09 AM   #23
MurkyRiversS13
Updated again with parts sold.
