Advertiser Announcements and Feedback This is where vendors can make announcements about upcoming promotions, events, items, etc. Vendors may also create threads here for the purpose of market research or other customer feedback. |
Adaptronics for 2jz [2jz swap made easy]
We noticed alot of Nissan/S chassis owners swapping 2jz in their cars. We offer a full plug & play to make your custom 2jz swap easier!!! ![]() ![]() The Adaptronic Toyota Supra & Lexus Plug-In Select ECU presents manual 2JZ-GE/GTE engine owners the simplicity of a plug-in ECU while also providing the versatility and advanced features gained with a standalone engine management system. The Plug-In Select Loom utilizes the factory wire harness and sensors to reroute the sensor signal wires to connect to your choice of the Adaptronic 420d or 440 Universal Select ECU's. This unique design configuration eliminates the hassle of splicing wires or performing a complete custom install normally required with any of the standalone unit while retaining the reliability of the stock wiring configuration. Automatic owners require a wire-in E420D or E440D Select to be used a piggyback( full fuel and ignition control) with the OEM computer. The functions you lose with the E420D, compared to the E440D, are: 1. No Flex Fuel Function. 2. No Adaptive Tuning Function. 3. No Traction Control Automatic cars require a wire in model to be used in parallel with OEM ECU. Wire in models available for automatic cars, SC400, GS300, IS300, etc. Check out these videos ! Look how easy it is to install! https://www.youtube.com/watch?v=7PzQaIW8X8A 800hp Supra on Adaptronics https://www.youtube.com/watch?v=ixjsxAQFPqw Mounfield Motorsports j34 adaptronics Install https://www.youtube.com/watch?v=HFMmPupdUCE#t=28 Adaptronics 420d w/2jz patch harness $1076 Adaptronics 440d w/2jz patch harness $1480 We are offering free shipping this month! Garage life 11128 Rush st. South El Monte , Ca 91733 Give us a call 626 455 0415 [email protected] |
Adaptronics on ice powered 2jz Kenny Moen!!!! https://www.youtube.com/watch?v=Np_DIJNpS_E
Video of 1jz Adaptronics drift car https://www.youtube.com/watch?v=YPxVWEj5VCc#t=48 |
Before getting into adaptronics we were tunning Microtech, haltechs, apexi power fc. When we first tried it, we were blown with all the features and how simple it was to use!
Tags |
2jz, adaptronic |
