Old 01-02-2009, 01:04 AM   #1
1ntr0
1ntr0 is an unknown quantity at this point
ka24
ok, ibe been reading the forums for a while and lost my account, but i finally got a 240. It has a Ka24e in it which has 200k+ on it and i want to swap in another Ka24e with lower mileage. To do this, what will i need since im looking for the same engine?
1ntr0 is offline   Reply With Quote
Old 01-02-2009, 01:20 AM   #2
cc4usmc
cc4usmc's Avatar
Location: Formerly Elk Grove/the916/95758/NorCal - Now teh 970
cc4usmc is close to perfectioncc4usmc is close to perfectioncc4usmc is close to perfectioncc4usmc is close to perfectioncc4usmc is close to perfectioncc4usmc is close to perfectioncc4usmc is close to perfectioncc4usmc is close to perfectioncc4usmc is close to perfectioncc4usmc is close to perfectioncc4usmc is close to perfection
You can't replace a ka with a ka.. it has to be something newer now.
This forum requires that you wait 120 seconds between reporting posts. Please try again in 115 seconds.
Originally Posted by s141996 View Post
is this exhaust california friendly? thnx lmk
cc4usmc is offline   Reply With Quote
Old 01-02-2009, 01:33 AM   #3
amdnivram
amdnivram's Avatar
amdnivram is an unknown quantity at this point
Send a message via AIM to amdnivram
sr20 anyone? hahah
amdnivram is offline   Reply With Quote
Old 01-02-2009, 01:40 AM   #4
s13 @ fullboost
Spirit Of Ecstasy
s13 @ fullboost's Avatar
are you swaping just the motor or the motor and trans. If you are just doing the motor I have one for sale low mileage P.M. me and you will need your tools lol
Old 01-02-2009, 02:06 AM   #5
mrmephistopheles
Inactive Admin
mrmephistopheles's Avatar
You should be good to go for a simple E to E swap, although there may be slight wiring differences between early 89s and later 89s-90s. Some had Hitachi distributors, some Mitsubishi, etc. I don't know that the wiring for that is different - just something you should be wary of.
Originally Posted by amdnivram View Post
sr20 anyone? hahah
If you're not going to be helpful, be quiet. I'd prefer to keep the Tech arenas largely sacrosanct.
Originally Posted by PHLIP
Old 01-02-2009, 02:25 AM   #6
drifterdave
drifterdave's Avatar
drifterdave is on the path to ruindrifterdave is on the path to ruin
u should need tools, another sohc ka, use ur stock tranny, and u can just pull all the wiriring attahed to the motor off. and then pull all the vaccum lines, drain fluids, cherry picker and tools. then u should be set. just rember were each connector went when taking it off. it will probley only take a weekend to finish or 1 day if every thing is ready to go.
keeping it gangster
drifterdave is offline   Reply With Quote
