Old 06-24-2012, 05:28 PM   #1
97SerevoSX
97SerevoSX is an unknown quantity at this point
S14 A/C problem
Hey all in short, I have a redtop Sr in my kouki. Wiring Specialties wiring harness. The A/C compressor will kick on just fine, R134a canister gauge shows good pressure when it's running, but the air never gets cold... I can swap an engine, take it apart and put it back together but I'm clueless to air conditioning..
97SerevoSX is offline   Reply With Quote
Old 06-24-2012, 05:30 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Try moving the slider to cold. If it's on cold, the lever could actually be broken off from the adjuster. Happened with my car.
edit: Hmm just read that you have an S14, not sure if there is a manual lever for the hot/cool door mixer. If not, the mechanism itself might not be switching.
Old 06-24-2012, 05:54 PM   #3
97SerevoSX
I think that is electric in the s14 or vacuum controlled. Either way, I hear it switch over and it isn't "heat" coming out of the vents. It's much cooler than that and when I slide it to hot it gets a lot hotter (like my heat does) so I don't think it's that..
Old 06-25-2012, 02:12 AM   #4
Butcher240sx
Butcher240sx's Avatar
Butcher240sx is an unknown quantity at this point
How long if ever was the system exposed to outside air? Was the drier replaced and suction put on the system when charged?
Don't Mess With Texas
Butcher240sx is offline   Reply With Quote
Old 06-25-2012, 11:59 AM   #5
97SerevoSX
Not for very long, maybe overnight while I had the compressor off to put the CodyAce bracket on. What's a drier? Also no..
Old 06-25-2012, 12:35 PM   #6
Butcher240sx
the drier is a cannister conected to your ac lines near the condensor. it removes moisture from the refrigeriant.i replace mine if i open the system at all. open overnight is long enough to ruin it. Mine was $8 new. open it and install it right away and go get a proper ac charge so they can pull vacume on the system. that sounds like your problem.
Old 06-25-2012, 01:21 PM   #7
97SerevoSX
Ahh right next to the battery (or where the battery used to be at least)? I will definitely try that. Is that something I can get at autozone?
Old 06-25-2012, 01:27 PM   #8
Butcher240sx
Yes sir. Make sure to get the o rings on straight, on the S13 the pressure switch is attached and I had to move it to the new one. It's a very important part of the system.
Old 06-25-2012, 01:42 PM   #9
97SerevoSX
Hmm what about on an S14. Mine's a 97 with all the original A/C stuff
Old 06-25-2012, 02:29 PM   #10
Butcher240sx
Not sure, find the drier and if there is a switch and harness on it thas the same.
Old 06-25-2012, 02:34 PM   #11
Butcher240sx
Nissan 240sx A/c Receiver-drier at Auto Parts Warehouse
This is the drier. Mine has 4ports and an inspection eye on the top. One port for press. switch, one line in, one line out, and one plugged.
Old 06-26-2012, 12:31 PM   #12
ka4life87
ka4life87 is an unknown quantity at this point
Did u draw a vaccum on ac system prior to filling freon? Will never get cold if air in system
ka4life87 is offline   Reply With Quote
Old 06-26-2012, 02:38 PM   #13
Butcher240sx
It will get a little cold, but suction will assure a full fill and a drier will remove all the moisture making the system much more efficient.
Old 06-26-2012, 02:49 PM   #14
S14DB
AFC #1
S14DB's Avatar
Originally Posted by ka4life87 View Post
Did u draw a vacuum on ac system prior to filling freon? Will never get cold if air in system
This is what I am thinking.
