04-10-2013, 06:08 PM | #1 |
Import Revival - OEM SR20DET Parts and Accessories
Welcome to Import Revival Inspected OEM and Aftermarket Japan-Specific Used Parts and Accessories Import Revival is committed to providing fellow Zilvia Members with hand-picked, Silvia, SR20DET, 180SX, and Skyline-related used, and sometimes new, parts and accessories, in an effort to assist fellow enthusiasts in maintaining reliability, and performance for your Japan-Spec powered, or modified projects. Having a healthy selection of local Importers from whom to choose various, interdependent Silvia, 180SX, and Skyline-related parts, for your selection, Import Revival is not limited by a restricted variation of parts thrown in a container - so very few times a year - that all that one is left to rely on, is the often detrimental consequence of that fact. Each and every Engine, Long Block, part, and accessory is handpicked personally, with diligence, and care taken to insure an adequate and legitimate condition of each available item, for members of the Zilvia community. Keep in mind, of course, that these parts, unless otherwise specified, are used, and normal wear and tear is expected. What I do guarantee, is that each items is described as accurately as possible. Import Revival consists of an extensive list of parts and accessories. Due to the nature of our parts and services, and the wide variety of categories our parts list is comprised of, but the limited supply within some of them, it is very difficult to use Zilvia’s efficient categorical divisions to their full use, and accurately provide the wide spectrum of categorical distribution we have to offer. Given the variety of handpicked parts we come across, opening up thread in the Drivetrain section for one LSD, or two sets of coil-overs in their appropriate category, does not yield an effective use for their intended purpose, or our ability to provide Zilvia members with our current and up-to-date list of such a wide variety of parts we pick each week. As a result, we will use the Engine’s Category as a hub to do just that – provide an up-to-date list of all parts available on any given day in this section. Thank you J. All parts with in this list are in stock, and will be updated numerous times a week. Please PM directly with any questions, concerns, or inquiries. Table of Contents A. SR20DET B. Brake Upgrades C. S13 Chassis D. S14 Chassis E. R32 Chassis F. R33 Chassis G. Drivetrain: Rear Ends (VLSD and Aftermarket) A. SR20DET 1. Intake Manifold • IACV • Throttle Bodies • Throttle Position Sensors • Coolant Lines and Hoses • Coolant Temperature Sensors • Intake Manifolds 2. Intake • Mass-Airflow Sensors • Rubber Accordian-Intake Tubes 3. Exhaust Side • Exhaust Manifolds • O2 Housings • O2 Sensors • Downpipes 4. Turbo • T25 Turbos • Compressor Elbows • Hot-pipe Elbows • Wastegates 5. Intercooler and Piping • Side-Mount Intercooler Kits 6. Fuel • 370cc Fuel Injectors • Fuel Rails • Fuel Pressure Regulator 7. Accessories • Power Steering Pump (Bolts available separately) • Power Steering Pump Bracket (Bolts available separately) • Alternator • Alternator Bracket (Bolts available separately) • Cam-Angle Sensor • AC Compressor • AC Compressor Bracket (Bolts available separately) • Starter • Starter Bolts 8. Wiring / Electronic • Full Uncut Engine Harness • Lower Harness • ECU (Engine Control Unit) • Ignitor Chip (Plates available separately) • Coil-Packs • Coil-Pack Harness • Transmission Harness G. Drivetrain • SR20DET 5 Speed Manual transmission (Compatible with KA Bellhousing) • Used Clutch • Used Flywheel • Transmission/Bellhousing Plate • VSS Vehicle Speed Sensor (Compatible with KA) • S13 VLSD (ABS available) • S14 VLSD • S15 Helical LSD • R32 GT-S VLSD • R32 GTR VLSD • R33 GT-S VLSD More to Come Daily Featured Product SR20DET S13/4 Splitfire Coilpacks Description: This Splitfire Coilpack System came from a running 180SX Redtop, from Japan, and is in excellent condition. Price: 265.00 plus shipping. SOLD Last edited by Import Revival; 04-10-2013 at 07:05 PM.. |
04-10-2013, 06:10 PM | #2 |
a. Sr20det - SR20DET S13 Clutch Fan - 1 - Sold - More Below SR20DET S14 WC - ECU - 1 SR20DET S13 Type X - J4 - ECU - 1 - Sold - - starters - 1 - S14 SR20DET - AirBox - 1 - Sold - SR20DET S13/4 - PowerSteering Pump - 1 -- Sold - More Below S13 SR20DET - MAFS - 1 SR20DET - Ignitor - 1 - SR20DET S13 Clutch Fan - 1 -Sold - More Below - S13/4 SR20DET CoilPacks - 1 - S13/4 SR20DET - Coilpack Harness - 1 S13/4 SR20DET - 370CC - Fuel Injectors - 1- Sold - SR20DET Starter - All models - 80.00 Shipped SR20DET 370CC Injectors 135.00 Shipped and Paypalled. SR20DET CAS - Cam-Angle Sensor - 100.00 Shipped Last edited by Import Revival; 05-14-2013 at 12:59 PM.. |
04-10-2013, 06:41 PM | #3 |
Aftermarket Tein S13 Super Street Coil-Over System with Camber Plates - 850.00 Description: These Tein S13 Super Street Coil-Overs with Camber Plates, are used, and in very good to excellent condition, and has come from a healthy 180SX, imported directly from Japan, housed, here, in North America. Normal wear and tear is expected to the surface of the unit, as should be expected. The absorbers compress and depress smoothly with linear movement, and the Camber Plates are adjustable, of course. SR20DET S13/4 Splitfire Coilpacks Description: This Splitfire Coilpack System came from a running 180SX Redtop, from Japan, and is in excellent condition. Price: 265.00 plus shipping. SOLD HKS VPC Vein Pressure Converter Description: This HKS VPC is a functioning Head unit utilized to replace the MAFS-Based SR20DET system. Please check to confrim this unit is applicable with your current SR20DET. Price: 265.00 plus shipping. Brake Upgrades R33 Skyline GTS-T 30MM (296MM Rotor Diameter) - 245.00Shipped Z32 Aluminum 30MM 225.00 Shipped Set #1 Z32 Aluminum 30MM 225.00 Shipped Set #2 Z32 30MM Iron Calipers 215.00 Shipped Set#1 Description: All Sets are Fully Loaded with used pads, shims, pins and fasteners. All rubber boots are intact. If you have any further questions or concerns, feel free to PM for further details and inquiries. Thank you J. Last edited by Import Revival; 05-14-2013 at 07:40 AM.. |
04-12-2013, 01:53 PM | #12 |
ARC Induction Box - S13 SR20DET - 285.00
Description: This ARC Induction Box is rare. There are light scratches and scuff, much of which can be polished at the user's discretion. It does come with an Air Filter, which is useable, but would eventually need a replacement. This is for a Stock MAFS for S13 SR20DET's. Import Revival Last edited by Import Revival; 04-12-2013 at 04:48 PM.. |
04-12-2013, 02:28 PM | #14 |
Description: These Tein S13 Super Street Coil-Overs with Camber Plates, are used, and in very good to excellent condition, and has come from a healthy 180SX, imported directly from Japan, housed, here, in North America. Normal wear and tear is expected to the surface of the unit, as should be expected. The absorbers compress and depress smoothly with linear movement, and the Camber Plates are adjustable, of course. Last edited by Import Revival; 04-12-2013 at 04:48 PM.. |
04-16-2013, 11:29 AM | #17 |
SR20DET Blitz LM Intake Filter - 70.00
(MAFS sold seperately) Description: This LM Intake is in like-new condition, and pictures do not do it justice. There is a slight indent in the fins, quite likely from storage, but is in excellent condition, with no rips, and no tears. Mafs is available separately. |
04-19-2013, 07:31 AM | #18 |
Import Revival - Featured Product - S13 Silvia Headlights
Sold Description: This set of Silvia Dual Projector Headlights, are in good condition. The outer casing on one side is has a superficial crack but can be adjusted with an adhesion of your choice and will mount and line up properly. This can be fixed, and will not effect the structural integrity of its settlement. Last edited by Import Revival; 05-02-2013 at 11:07 AM.. |
04-19-2013, 07:58 AM | #19 |
Import Revival - S13 Silvia Corner Lights
Sold Description: This set of Silvia Amber Corner Lights, are in good condition. One side has one tab is chipped off, but with a brace of your choice will otherwise yield a clean, strait, and proper fitment. This can be fixed, and will not effect the structural integrity of its settlement. Last edited by Import Revival; 05-02-2013 at 05:57 AM.. |
04-23-2013, 08:05 PM | #23 |
Rare Japan-Spec S15 Blue Alcantara Front Seats
S15 Spec R Blue Alcantara Seats - S13/4 Chassis - 800.00
Description: These Rare Japan-Spec S15 Blue Alcantara Front Seats, are in very good to excellent condition. They are a direct bolt-in upgrade for the S13 and S14 Chassis, and a considerable upgrade, particularly in contrast with the S13 Front Seats. |
04-28-2013, 08:49 PM | #29 |
Tomei 2-Way LSD - Sold 5-Bolt Output shaft and Axles available. PM for details. Description below.
Description: This Tomei Limited-Slip Differential is imported from Japan. The unit is as you see depicted, the oil was very clean when removed. This differential, is of course used, and is in very good condition. Last edited by Import Revival; 05-02-2013 at 05:59 AM.. |
