Old 06-29-2015, 02:35 PM   #1
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Built S14 SR20DET Notchtop Partout--BC//CP//Eagle
I am parting with my spare motor as I am extremely indecisive and have decided to go a different route. History of the motor is as such: Friend had the motor built, drove the car for about 3k miles, sold it to fun his drift project, and the new own immediately pulled it to go v8. It sat in his shop for a little while and the I bought it. Now I don't want it. All parts sold as is.NO TURBO
I have not disassembled the bottom end, but everything else is off and looks great.
All prices are obo. Shipping is offered at buyer's expense, and buyer also pays paypal fees. I will ship most things USPS priority.
S14 SR20 Bare Block--$300SOLDD!; Was hot tanked, decked, and honed. The deck looked perfect, and the crosshatches are still visible in the cylinder walls.
New S14 SR20DET Oil Pump--$115; 3k miles on it. It was painted with high temp aluminum paint along with the block.
CP Pistons & Eagle Rods--$500SOLD!!; Pistons are standard bore and 9.0:1 compression ration. These are practically new, have a little bit of carbon on top. No spun bearingsedit:These pistons look great. I wiped them off and a lot of the carbon came off. I worked a little more on piston 4 and it looks brand new. Skirts look amazing.
SR20DET Crank--$165Sold!!!; Excellent condition
SR20DET Crank Pulley--$35; cheap because there is a chip on the outer lip. This will not affect performance
S14 SR20DET Built Head--$375; Head was hot tanked and decked. Has Brian Crower Titanium Retainers and Springs(BC0200 kit), and new OEM valve seals.Includes the cam caps, squirters, lifters, and rocker arms. The valve shims were removed and labled so that they go back in properly.
ARP Head Studs--$90SOLD!!; Torqued only once. In original box
ARP Main Studs--$90; Torqued only once. In original box
S14 SR20DET OEM Cams--$35; Excellent condition, no cam gears.
S14 SR20DET Intake Manifold--$80; Complete with throttle body. Does not include IACV or throttle cable bracket. Includes working CTS
S14 SR20DET IAC--$45
S13 SR20DET Turbo Manifold--$35SOLD!!
SR20DET OEM Flywheel--$55; Great condition. A little bit of surface rust from sitting, but otherwise perfect.
S14 SR20DET Water Neck--$40; Great condition. Includes temp sender thing.
S14 SR20DET CAS--$90SOLD!!; Perfect condition.
S13 SOHC MAF w/ Filter Adapter--$35SOLD!!
S14 SR20DET Fuel Rail w/ FPR--$45; Great condition. Includes injector caps as well.
S14 SR20DET FPR--$30; This is a spare, not from the rail above.
S14 SR20DET Valve Cover--$110Sold!!!; It has been painted, but wasn't a very good job. Great condition otherwise.
SR20DET Coil Packs--$70; 3 are in excellent shape, the forth is also in good shape but missing the boot, so it's free. Includes great condition subharness
SR20DET Upper Oil Pan--$30; Have 2 of these.
SR20DET Lower Oil Pan--$40SOLD!!; Not dented
If you don't see something, feel free to ask. Once I take apart the short block I'll update the missing pictures and add to the list. Feel free to ask any questions and/or make offers.
Thanks for looking.
Old 06-30-2015, 09:33 AM   #2
Quesadilla
Quesadilla is an unknown quantity at this point
I'm interested in the manifold. I'm also definitely not in Florida too so I can pick up if you're not too far
Quesadilla is offline   Reply With Quote
Old 06-30-2015, 09:51 AM   #3
Driftzenki
Driftzenki is an unknown quantity at this point
whats the bore on the cp pistons and would you part them?
Driftzenki is offline   Reply With Quote
Old 06-30-2015, 01:57 PM   #4
Hoffman5982
Trader Rating: (25)
Intake manifold or exhuast? And I'm located in Pensacola
Derp, can't believe I forgot to post the specs.
The pistons are standard bore and 9.0:1 c/r. Atm I'm not looking to separate but I would if someone showed interest in the rods.
Old 07-01-2015, 12:01 PM   #5
Hoffman5982
Trader Rating: (25)
To the top!
Old 07-02-2015, 08:50 AM   #6
Hoffman5982
Trader Rating: (25)
Bump feel free to make offers!
Old 07-02-2015, 08:58 AM   #7
Quesadilla
Do you have the stock oil catch can with hoses?
Old 07-02-2015, 10:16 AM   #8
Hoffman5982
Trader Rating: (25)
I wasn't aware the s14 sr's had oil catch cans from the factory
Old 07-02-2015, 10:28 PM   #9
Hoffman5982
Trader Rating: (25)
I disassembled the bottom end today and was very impressed. Everything looks immaculate. Better pictures have been uploaded. Also realized a couple of parts weren't what they appeared to be and updated the info.
Feel free to shoot me some offers, but be reasonable. I'm motivated to sell.
Old 07-03-2015, 12:03 AM   #10
Kingtal0n
Kingtal0n's Avatar
When you say standard bore, are they standard bore undersized to fit the OEM clearance, or standard bore with requires boring to the larger piston/wall clearance required by forged pistons?
https://tinyurl.com/turbo240
Old 07-03-2015, 12:11 AM   #11
Hoffman5982
Trader Rating: (25)
Standard bore as in 86mm, same as stock
Old 07-03-2015, 11:49 PM   #12
Hoffman5982
Trader Rating: (25)
To the top!
Old 07-06-2015, 12:23 AM   #13
Hoffman5982
Trader Rating: (25)
Someone spend money. Money spendin is gooooood
Old 07-06-2015, 03:23 PM   #14
Hoffman5982
Trader Rating: (25)
Bump to the top!
Old 07-07-2015, 11:50 AM   #15
Hoffman5982
Trader Rating: (25)
I've had a couple of nibbles, but no bites. Please remember everything is obo!
Old 07-08-2015, 10:31 AM   #16
Hoffman5982
Trader Rating: (25)
Oil pan sold. Please remember that if you'd like more pictures of something, you just have to shoot me a pm and ask!
Old 07-13-2015, 12:04 AM   #17
Hoffman5982
Trader Rating: (25)
Bump, still have most of this. Crank is pending sale
Old 07-14-2015, 03:28 PM   #18
Hoffman5982
Trader Rating: (25)
Bump, pistons/rods may be pending sale
Old 07-15-2015, 02:27 PM   #19
kyle1a2
kyle1a2 is an unknown quantity at this point
Bump, oil pan showed up today in great shape. Excellent seller!
kyle1a2 is offline   Reply With Quote
Old 07-16-2015, 02:18 PM   #20
Hoffman5982
Trader Rating: (25)
Thanks!
Lower oil pan and pistons/rods sold!
Old 07-18-2015, 04:20 AM   #21
Hoffman5982
Trader Rating: (25)
Maf sold, both vtc gears pending
Old 07-19-2015, 12:58 PM   #22
Hoffman5982
Trader Rating: (25)
I guess the crank is no longer pending, neither are the vtc gears. To the top!
Old 07-19-2015, 01:35 PM   #23
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Good stuff here.
Old 07-20-2015, 07:49 PM   #24
Hoffman5982
Trader Rating: (25)
^Thank you sir
To the top.
Old 07-21-2015, 08:47 AM   #25
TheRealSy90
TheRealSy90's Avatar
Willing to ship upper oil pan? If you can verify that none of the threaded holes are stripped.
Such a good signature.
Old 07-21-2015, 05:53 PM   #26
Hoffman5982
Trader Rating: (25)
Yes. Give me a day or two to get you a shipping quote for you I'll PM you when I do
Old 07-23-2015, 01:58 AM   #27
Hoffman5982
Trader Rating: (25)
1 VTC Gear and Solenoid SOLD! Crank is back to pending status. The RealSy90 I haven't forgotten about you, I just haven't been able to get out to ups or usps for a quote.
Old 07-25-2015, 10:38 AM   #28
Hoffman5982
Trader Rating: (25)
Crank sold, block pending
Old 07-25-2015, 11:38 AM   #29
mreid
mreid is an unknown quantity at this point
I messaged you some time ago about the block. If it doesn't go, I'll still take it immediately.
mreid is offline   Reply With Quote
Old 07-26-2015, 06:27 PM   #30
Hoffman5982
Trader Rating: (25)
I'll let you know. I have a guy that has been planning to grab it on the 31st. If it falls through you'll be the first to know
