Old 04-12-2020, 04:22 PM   #1
cjturbos14
cjturbos14's Avatar
cjturbos14 has a spectacular aura aboutcjturbos14 has a spectacular aura aboutcjturbos14 has a spectacular aura aboutcjturbos14 has a spectacular aura aboutcjturbos14 has a spectacular aura aboutcjturbos14 has a spectacular aura about
1989 Mazda Rx7 Turbo Fresh Rebuild
1989 Mazda Rx7 13b turbo
Clean Title
185k miles
Freshly Built Motor by Angel Motorsports
Streetport
Stud kit
Solid Dowel kit
Engine Assembly Balanced(Mazdatrix)
Rotor Side Cutting (Mazdatrix)
FD Oil pressure Regulator
Oil Pan Baffle Plate
New Air Intake Gaskets
Aeromotive Fuel Pump
Aeromotive FPR
6 AN lines
1000cc 1300cc injectors
Adaptronic M1200
Angel Motorsports Harness
Action Stage 2 Clutch
Turbo LSD
New Turbo Axles
Susp Technique Springs
Tokico struts
Taurus Fan wired to be controlled by ECU
Koyo NFlow Radiator
Banzai Motor Mounts
3in Downpipe
3in Exhaust
Innovative Wideband
S2000 Push Start
JDM Cluster
Engine Bay previously painted
Door jams painted
S5 OEM lip
S5 OEM fogs
Glass Headlights
LED Bulbs
Headlights wired to light FTP lenses and flip up as well
On a street/break in tune. 800 miles into break in. Wiper motor needs to be wired in, auto belts don?t work and will need a tune after break in....Car runs great though and starts every time...
Car was painted 2 years ago. Still shines but will need minor details fixed. Motor work is done which is the most expensive and time consuming.
Mainly looking for a Swapped S13 hatch or Clean Ae86.... I just realized I don?t need 2 FCs so one has to go.... If I had to put a price on it 11k obo
cjturbos14 is offline   Reply With Quote
Old 08-09-2020, 02:07 PM   #2
tinktink
tinktink's Avatar
tinktink is an unknown quantity at this point
Is this still available?
tinktink is offline   Reply With Quote
Old 11-19-2020, 11:28 PM   #3
Alha93
Alha93 is an unknown quantity at this point
Clean Title
185k miles
Streetport
Stud kit
Solid Dowel kit
Aeromotive FPR
6 AN lines
Adaptronic M1200
Turbo LSD
New Turbo Axles
Tokico struts
Koyo NFlow Radiator
Banzai Motor Mounts
3in Downpipe
3in Exhaust
Innovative Wideband
S2000 Push Start
JDM Cluster
Door jams painted
S5 OEM lip
S5 OEM fogs
Glass Headlights
LED Bulbs
Still avail? I?m interested. Please text me 858-205-7895
Alha93 is offline   Reply With Quote
