Old 09-18-2010, 08:57 PM   #1
PomiDori
PomiDori is an unknown quantity at this point
s14 Brakes acting wierd(searched)
Setup
ABS deleted
300zx master cylinder new
300zx front and rear calipers bleeders on top of the calipers
ebc yellow pads
Blackworks(Exactly the same as Ksport)Ebrake
auto brake booster
When the car is not running pedal and Ebrake is stiff,once u start driving and push the brake pedal it goes all the way to the floor and no stopping power,but if u pump brake pedal twice it works perfect.Ebrake is stiff, but nolocking
The way I bleed the system is pump brake pedal 2-3time till stiff open the bleeder push the pedal down then Ebrake,closed the bleeder.There was no bubles.
Help!
PomiDori is offline   Reply With Quote
Old 09-18-2010, 09:02 PM   #2
s13silvia123
s13silvia123's Avatar
get yourself one of these much much more easier to bleed. did you you bleed the rear calipers first then move to the fronts
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
Old 09-18-2010, 09:07 PM   #3
PomiDori
where I can buy this kit?
yes,rear pass>rear driver>front pass>front driver side.
Old 09-19-2010, 10:31 PM   #4
PomiDori
Bought vacuum kit like that and bench bleed kit,bleed it no air in master and no air in calipers and still no change.
I will try to adjust the stud on the brake booster.
Old 09-19-2010, 10:39 PM   #5
Vicious Beaner!
Vicious Beaner!'s Avatar
Trader Rating: (38)
Vicious Beaner! is an unknown quantity at this point
Feedback Score: 38 reviews
yeah same problem here . i used 1 of those bleeder pumps and no air in the system and still no change?? same problem like this guy. you think it can be the master cylinder????
Vicious Beaner! is offline   Reply With Quote
Old 09-22-2010, 06:41 PM   #6
PomiDori
Update figured that bleeders in the rear was wrong size(some standart size),but they never leak.
bought some 10m1.0 bleeders gonna try tomorrow.
Old 09-22-2010, 08:59 PM   #7
SHIFTrl240
SHIFTrl240's Avatar
SHIFTrl240 is an unknown quantity at this point
So you are saying if you have the car off and pump the brakes its hard? Then, if you hold the brakes down while turning the car on it falls to the floor?
SHIFTrl240 is offline   Reply With Quote
Old 09-24-2010, 06:31 PM   #8
PomiDori
no stays hard.
Old 09-24-2010, 06:33 PM   #9
SHIFTrl240
SHIFTrl240's Avatar
When does it fall to the floor?
Old 09-24-2010, 10:31 PM   #10
PomiDori
Once u drive the car it goes to the floor.I know it sound like bad brake booster,but
I checked master cylinder and brake booster according to FSM.
Old 10-17-2010, 05:54 PM   #11
PomiDori
update
there is a rod with nut under the dash by the brake pedal,so the nut was loose and the rod it was spinning freely. rod adjusted,nut tight-problem fixed!
