Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Intake & Exhaust
Old 08-09-2010, 01:26 PM   #91
e1_griego
e1_griego's Avatar
Trader Rating: (24)
e1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond reputee1_griego has a reputation beyond repute
Feedback Score: 24 reviews
Just wanted to post and say this is an *awesome* piece.
I bought a used one locally and installed this weekend. Only (potential) issue I might have is that the flange is so thick on the back of the turbo that I may need to re-stud the back of the turbo (or back the studs out some more) to get the studs to protrude all the way through the nuts. Right now I'm probably one thread shy on every nuts.
Gonna leave it like it is and keep an eye on it, but I'm very very very impressed by fit and finish.
e1_griego is offline   Reply With Quote
Old 08-11-2010, 10:45 PM   #92
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
Thanks!
If there is any lack of confidence in the studs even that you'd like one more thread, I recommend restuding it while its all apart because exhaust system reliability is a reoccurring issue on most drift cars and we like to do whatever we can to to make it more reliable. That's why we use the half inch thick flange to prevent warping and to increase uniform contact force on the gasket.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 11-02-2010, 01:21 AM   #93
dongoesby
dongoesby's Avatar
dongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of light
I'm also on the same boat of using tomei manifold. I don't want to get rid of it. Is it possible for you guys to make minor adjustment at the union of the elbow and flex section?
If so, you have my word for a purchase from me. (I have been trying to get one since feb this year.)
dongoesby is offline   Reply With Quote
Old 11-02-2010, 06:09 PM   #94
DC Dan MAX USA
Trader Rating: (79)
I must have the car in the shop to make the adjustment for your tomei manifold. There is no other way.
Old 11-09-2010, 08:51 PM   #95
ScarredOne
ScarredOne's Avatar
ScarredOne will become famous soon enoughScarredOne will become famous soon enoughScarredOne will become famous soon enough
Dan, can you make the MaxFlex Cobra with a longer straight (under the floorboard) section to make using a separate test pipe unnecessary?
If so, what would the cost be?
Thanks.
ScarredOne is offline   Reply With Quote
Old 11-09-2010, 09:06 PM   #96
Drifting-pedobear
Drifting-pedobear's Avatar
Drifting-pedobear is an unknown quantity at this point
he addressed that earlier, the answer was no.
ill be ordering mine in a few hours. SIIICK!
RIGHTWHEELDRIVE.com
Drifting-pedobear is offline   Reply With Quote
Old 11-17-2010, 07:20 PM   #97
Drifting-pedobear
hours was incorrect, but it has been BOUGHT!
looking forward to this item.
RIGHTWHEELDRIVE.com
Old 11-20-2010, 04:19 PM   #98
DC Dan MAX USA
Trader Rating: (79)
thanks!
Now for RB25 swap on Mckinney mounts!
Same 100% stainless construction, half inch flanges, divorced dump tube, vertical flex, and adjustable solid tranny mount as our popular SR20 cobra! Available now for RB25 motor swap+OEM turbo from Parts Shop MAX USA $400 + SH
http://www.youtube.com/watch?v=di1ln0os0sU
We combined the downpipe with a custom solid mounted straight exhaust for some excellent ground clearance, power, sound and reliability.
Old 04-09-2011, 08:46 PM   #99
JaindlS13
JaindlS13 is an unknown quantity at this point
So, "divorced dump tube". Is this a true dump tube, like hit full boost and it screams like a banshee dump tube, or is this some kind of terminology I am not familiar with. Sorry for the amateur question. Thanks guy
JaindlS13 is offline   Reply With Quote
Old 03-04-2012, 10:06 AM   #100
RocketOgre
RocketOgre's Avatar
RocketOgre is an unknown quantity at this point
Pictures make it pretty clear, it is a separated tube so the wastegate exhaust doesn't mix with the turbine exhaust immediately, they are kept seperate until the flex pipe section to reduce turbulence. No screaming.
Sidenote, just got my tax return gonna be ordering one of these for myself soon, just gotta get all the other pieces put together.
'89 hatch DD'd SR'd 2871'd - Sold
2006 Legacy GT Wagon
RocketOgre is offline   Reply With Quote
Old 06-23-2013, 10:31 PM   #101
alwyzDTF
alwyzDTF's Avatar
alwyzDTF is an unknown quantity at this point
For people having problems with the divider mounting to their turbo due to the turbo already having one built in. Are you guys cutting the divider out of the down pipe or out of the turbo?
alwyzDTF is offline   Reply With Quote
Old 07-25-2013, 12:47 PM   #102
DC Dan MAX USA
Trader Rating: (79)
we cut it out of the downpipe for you if you select T28 turbo option in cart.
Old 10-15-2013, 08:10 PM   #103
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Do you know when you'll have these back in stock?
Thanks!
Old 12-09-2013, 07:44 PM   #104
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Wondering when these will be back in stock.
Old 02-19-2014, 01:24 AM   #105
zefside_s15
zefside_s15's Avatar
zefside_s15 is an unknown quantity at this point
I've been trying to buy this downpipe through your website but it won't complete the transaction, you already gave me a freight cost but the site doesn't allow a shipping option?
zefside_s15 is offline   Reply With Quote
Old 11-19-2016, 08:55 PM   #106
TheRealSy90
TheRealSy90's Avatar
For everybody with these downpipes. Has anyone been able to run 5 bolts through the turbo flange? No studs. I'm asking because I want to order Stage 8 locking bolts for the turbo flange, but I can't tell if there's enough room between the bottom bolt holes and the pipe to slip the bolts in there.
Such a good signature.
Old 11-20-2016, 11:18 PM   #107
RocketOgre
RocketOgre's Avatar
You won't need them. I ran this DP with factory studs and fresh nuts never had a single nut back off, didn't even get loose. Just get a set of ratcheting wrenches, a stubby, and a crows foot so you can get all 5 tight the first time.
Sent from my LG-H820 using Tapatalk
Old 11-21-2016, 08:53 AM   #108
TheRealSy90
The T2 turbine housing for my td06 didn't come with any studs installed so that's why I was considering using locking bolts.
Old 01-24-2017, 07:36 PM   #109
Powered by Jay
Powered by Jay is an unknown quantity at this point
I read that the Tomei Expreme SR20 exhaust manifold has issues with this downpipe but what about the KA24DET Tomei Expreme exhaust manifold? Anyone have this setup?
Powered by Jay is offline   Reply With Quote
Old 01-24-2017, 07:47 PM   #110
lewisfk
lewisfk's Avatar
lewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond reputelewisfk has a reputation beyond repute
I need a down pipe that will fit a full race t3 manifold setup and connect to the exhaust.
lewisfk is offline   Reply With Quote
Old 04-13-2017, 12:43 PM   #111
Itsalexwoo
Itsalexwoo's Avatar
Itsalexwoo is an unknown quantity at this point
Now when you say it hits the transmission with a tomei manifold. How bad are we talking cause I'm installing a CD009 and my current turbo elbow hits right at the 3 bolt flange
Itsalexwoo is offline   Reply With Quote
Old 04-13-2017, 06:11 PM   #112
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Late pass, but I will tomorrow... lol
Old 04-14-2017, 07:06 PM   #113
Powered by Jay
Did you attempt this setup?
Old 04-14-2017, 07:08 PM   #114
TheRealSy90
You have a Tomei turbo manifold? I have this downpipe with my sr20/cd009 and there's a ton of clearance. But I'm on a stock manifold.
Old 04-14-2017, 07:28 PM   #115
Itsalexwoo
Itsalexwoo's Avatar
Yeah I pushes it way close to the trans like I can't even bolt the manifold up. About how far would you say the down is from the trans?
Old 04-15-2017, 08:52 PM   #116
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
I attempted and succeeded.
I had a hybrid SR-> KA-T manifold.
Now I have the Tomei. My installer said that the fitment with the pbm pipe was better to the chassis as it lowered the turbo. Making it not hug the trans tunnel so tightly.
It even made the cobra trans tunnel bracket match up perfectly.
My exhaust as a result is a bit lower, but it doesn't hit the car causing vibrations.
I planned on raising my car a bit going forward. So I'm happy. Sounds great.
Old 03-05-2020, 06:40 AM   #117
frsh2fourty
frsh2fourty's Avatar
frsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura aboutfrsh2fourty has a spectacular aura about
Send a message via AIM to frsh2fourty
Bumping an old thread but I've had a lot of discussion with people about fitment with this downpipe using the SR20 Tomei manifold. I just got the engine dropped and there was plenty of clearance
The trans clearance looks tight in the pic but there's a little more space than the pic shows.
frsh2fourty is offline   Reply With Quote
Old 03-05-2020, 06:41 AM   #118
frsh2fourty
whoops, double post
