Old 04-09-2013, 03:53 PM   #5251
blessedhellrider
blessedhellrider's Avatar
blessedhellrider is an unknown quantity at this point
tuning carb boosted is just like tuning an n/a carb. its the FPR that is important.
im pretty sure you need to up the CFM.
its the carbs with the boxed in enclosures(non blow through) ,that would be a B!
but what do i know!
blessedhellrider is offline   Reply With Quote
Old 04-09-2013, 06:12 PM   #5252
Yanior
Yanior is an unknown quantity at this point
LOL.Yeah i thought of that too. But its just a mock up,its not the actual thing going on it..just put it all together to see how it looked..
Originally Posted by Chrischeezer View Post
"shit is good"
^ BOV opens... air/fuel comes blowing out onto that manifold...goodnight
Yanior is offline   Reply With Quote
Old 04-09-2013, 06:31 PM   #5253
Yanior
This is the Carb ill be running on this setup..
Old 04-09-2013, 08:39 PM   #5254
IIIXziuR
IIIXziuR's Avatar
Kingston, that exhaust set-up looks amazing! Great work =)
Old 04-09-2013, 08:56 PM   #5255
singlejzpower
singlejzpower's Avatar
singlejzpower is an unknown quantity at this point
awesome job!
singlejzpower is offline   Reply With Quote
Old 04-09-2013, 09:15 PM   #5256
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
n00b post but what would you guys charge to weld these in? Having a hard time finding someone local that can do it.
GKtech Subframe Weld in Reinforcement Plates - Nissan S14/S15/R33/R34 - Enjuku Racing Parts, LLC
Old 04-10-2013, 11:39 AM   #5257
PerilousActs
PerilousActs is an unknown quantity at this point
Made a 3" down pipe for my st165 celica all trac beater shitbox from an old honda down pipe.
Only my second time working with stainless, so welds at the end were significantly better than at the start >_<. Too much heat haha.
PerilousActs is offline   Reply With Quote
Old 04-10-2013, 11:43 AM   #5258
Yanior
awesome job there.looks good to me,practice is the key to success.
Old 04-10-2013, 01:30 PM   #5259
[email protected]
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
Carb has to be modified for pressurized bowls
Also timing will he locked
We have had several carb blow thru 4 bangers
MunkyW3rkz Racing
S@nt0s is offline   Reply With Quote
Old 04-10-2013, 02:14 PM   #5260
Nezahualcoyotl
Nezahualcoyotl's Avatar
Nezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-knownNezahualcoyotl is making his/her stupidity well-known
Maybe dumb question, but would it be possible to use a stock muffler for a custom exhaust?
Nezahualcoyotl is offline   Reply With Quote
Old 04-10-2013, 05:25 PM   #5261
[email protected]
S@nt0s's Avatar
yes but it create backpressure which in turn will effect power thus eliminating the all purpose of having a exhaust.
now you can have a good flowing muffler thats quiet just have to find a give and take.
MunkyW3rkz Racing
Old 04-10-2013, 05:43 PM   #5262
Yanior
Idk much about carbs to be honest. But i talked to them and they said this would work for my setup,and it says "QUICK FUEL 750 ANNULAR MECH BLOW THROUGH GAS DRAG RACE Q-750-BAN
Calibrated for blow-through applications
So im guessing it will be bolt on and go,besides properly jetting it and tuning it..as well i will need a boost reference FPR to raise the fuel PSI as more boost goes up or something like that..but thanks for the info.
Old 04-12-2013, 12:54 AM   #5263
Nezahualcoyotl
where's a good place to get piping for an exhaust near 92704?
Old 04-12-2013, 06:19 AM   #5264
Yanior
I'm not from your area but i would think any well know muffler shop around your area should carry exhaust tubing...I Googled up something around your area dont now how far it it but they dedicate themselfves just to muffler and headers check em out. Good luck tho
Riverside, CA 92509
Phone: 951-360-2474
Old 04-12-2013, 07:25 AM   #5265
ultimateforce
ultimateforce's Avatar
ultimateforce is an unknown quantity at this point
You need a proper torch and cup setup too.
Assistant Fabrication Manager / Welder at Raw Brokerage
ultimateforce is offline   Reply With Quote
Old 04-12-2013, 02:24 PM   #5266
PatMan000111
PatMan000111's Avatar
PatMan000111 is an unknown quantity at this point
Proper torch won't help that. That'll prolly crack pretty quickly, you can't overheat stainless like that
Set your machine at 45amp and get used to it like that. if you need more than that to do 16ga without back purging you're doing it wrong.
-RussellPants
PatMan000111 is offline   Reply With Quote
Old 04-14-2013, 02:03 PM   #5267
serious_student
serious_student's Avatar
serious_student is an unknown quantity at this point
s13 budget build
Nothing major, but I figured I would contribute. Here are a few shots from my S13 budget build I did a few years ago.
Chassis prep
the fun part, seam cleaning
stitching
Engine prep
A/N fitting for IAC (be careful with heat on this one)
Waterline loop
Engine
motor drop (not fab i know)
Intercooler mockup and mounting
intercooler and piping/intake construction
about 90% complete
I apologize for the lack of quality in the pictures, I shot this build with a camera phone, and I was on a time crunch, so only took pics ever so often.
serious_student is offline   Reply With Quote
Old 04-16-2013, 07:39 AM   #5268
gretz
gretz's Avatar
gretz is a jewel in the roughgretz is a jewel in the roughgretz is a jewel in the roughgretz is a jewel in the roughgretz is a jewel in the roughgretz is a jewel in the roughgretz is a jewel in the rough
machining my own 1jz vvti T4 manifold, should be rad when its done
gretz is offline   Reply With Quote
Old 04-17-2013, 09:28 PM   #5269
kingston240
kingston240's Avatar
kingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond repute
SO pumped with how the intake pipe for the turbo kit im building turned out.
for those of you not subscribed to my facebook page, here is a pic. couple more on my page.
The customer is getting excited to say the least....
www.facebook.com/HellaFab
kingston240 is offline   Reply With Quote
Old 04-18-2013, 03:28 AM   #5270
AdrenalineS14
AdrenalineS14's Avatar
AdrenalineS14 is an unknown quantity at this point
Alright guys just a quick answer/opinion.... I just asked a local shop in my area on the cost of getting my S14's engine bay fully stitch welded and the front tubs redone, i was quoted 500 just for stitch welding and another 1100 to redo the tubs does that sound like a fair price? btw the motor is out. thanks in advance for your input guys.
AdrenalineS14 is offline   Reply With Quote
Old 04-18-2013, 07:57 AM   #5271
[email protected]
S@nt0s's Avatar
yea seems fair based on labor hours needed to perform everything.
ask if you did the prep (stripping, sanding or weld areas) and cutting the stock front tubs out if it will cut cost on there part. up to you if you can do those things to save some $
MunkyW3rkz Racing
Old 04-18-2013, 11:07 AM   #5272
PerilousActs
This is awesome. How do you seal the two halves together?
Old 04-18-2013, 11:20 AM   #5273
gretz
gretz's Avatar
They'll be welded together, then inserted through the flange and welded on the head side, then decked for awesomeness lol... Should be pretty unique
Old 04-22-2013, 12:00 PM   #5274
McRussellPants
McRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond reputeMcRussellPants has a reputation beyond repute
As a shop owner I don't usually drop the price for stuff like that. You're more likely to back the fabricator into a corner with something you shouldn't have cut, or they'll have to re sand everything to their liking anyway.
Those prices seem on the high side, but if you think their work is worth paying that then its probably worth it to pay more.
McRussellPants is offline   Reply With Quote
Old 04-22-2013, 03:10 PM   #5275
hb24drftr
hb24drftr's Avatar
hb24drftr is an unknown quantity at this point
There are so many people out there that claim to be fabricators now a days. Those are legit prices back before the economy took a shit and everyone decided that they were all of the sudden a fabricators, and started lowballing jobs and pretty much putting a lot of more legitimate shops out of business. Just remember, like McRussell said, legit work deserves a legit price.
hb24drftr is offline   Reply With Quote
Old 04-24-2013, 09:56 AM   #5276
yokotas13
yokotas13's Avatar
i [email protected]
IMG_4191 by Flsimages, on Flickr
yokotas13 is offline   Reply With Quote
Old 04-25-2013, 07:39 AM   #5277
gretz
gretz's Avatar
fit like a glove... im excited to see if it performs like it is expected to...
Old 04-26-2013, 09:38 AM   #5278
yokotas13
yokotas13's Avatar
http://www.youtube.com/watch?v=UTYgS1peVR4
the process
Old 04-28-2013, 08:53 PM   #5279
PerilousActs
Picked this up for $300 today. Think I did good...
Now to figure out what the hell I'm doing. I know nothing about lathes haha
Old 04-28-2013, 09:30 PM   #5280
Laotian240
Laotian240's Avatar
Laotian240 is an unknown quantity at this point
thats a nice piece of machinery you got there for ww2 old lathe. looks good, i like how the la blondes run though. they're easy to use but tooling is the expensive part.
Laotian240 is offline   Reply With Quote
