95 s14 check engine light dont work, need help!!!
Needs some help with some wiring issues with my check engine light. Never noticed it wasn't working properly with the key on "ON" position. The light still comes on if i make it throw out a code on purpose though. I can't seem to find any better wiring diagrams other than the FSM EL diagrams.
chased the orange wire from the cluster to the ecu and i have continuity. i believe that the circuit for the light is under a 2 step control on the grounding circuit controlled by the ecu but I can't figure out which grounds to look at.
Has anyone had this issue before any input on it is greatly appreciated.
-GSpeed4ever-
