Old 07-19-2011, 08:41 PM   #1
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Angry SR20DET falls on its face @ 5.5K rpms
I've been working on my friends SR20 and I can't figure out why it's doing this. It's almost like it hits fuel cut, or a rev limiter, and just completely stops building boost, accelerating, etc.
There are no boost leaks, AFR's are good, etc.
His set up is:
S15 T28 Turbo at stock boost
Apex'i AVCR
Sard 550cc injectors
Z32 MAF
I have checked timing,ignition timing, i've tried turning the AVCR to "off," I've checked plug gaps, etc. I've tried all I can think of.
Also tried to completely remove the AVCR from the picture, by unplugging it, and routing the wastegate straight to the hotpipe, instead of the boost controller. Same issue.
Any thoughts?
StryfeS13 is offline   Reply With Quote
Old 07-19-2011, 09:23 PM   #2
sebastianwrx
sebastianwrx's Avatar
Trader Rating: (18)
sebastianwrx is an unknown quantity at this point
Feedback Score: 18 reviews
sebastianwrx is offline   Reply With Quote
Old 07-19-2011, 09:42 PM   #3
Sileighty_85
Sileighty_85's Avatar
What are the plugs gapped to?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-19-2011, 10:00 PM   #4
thizzen4
thizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymore
CHECK UR TPS SENSOR next to throttle body might have a dead spot in it holddd it all the way down with a screw driver and have some one rev and see if its thatt
thizzen4 is offline   Reply With Quote
Old 07-19-2011, 10:12 PM   #5
sebastianwrx
Trader Rating: (18)
0.28 and tps was fine we checked
Old 07-19-2011, 10:20 PM   #6
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
fuel pump checked yet?
edit: what is the fuel pump?
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 07-19-2011, 10:45 PM   #7
sebastianwrx
Trader Rating: (18)
walbro 255
Old 07-19-2011, 10:54 PM   #8
chininsan
chininsan is an unknown quantity at this point
do you have the stock rubber intake piping?
check that. sometimes the spring inside of it screws up.
chininsan is offline   Reply With Quote
Old 07-19-2011, 11:07 PM   #9
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
boost leak
Old 07-19-2011, 11:28 PM   #10
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Yes, it has stock rubber intake piping.
How can the spring cause it to do this?
Originally Posted by codyace View Post
boost leak
We've checked all couplers, even made a boost leak tester...there is no boost leak. However, the Greddy RS bov has a little hole on the back of it (factory), and it leaks during the boost leak test, why is this?
Old 07-20-2011, 12:50 AM   #11
sebastianwrx
Trader Rating: (18)
hi just checked my buddy car and lil update when the car was cold it goes the boost no problems and no fuel cut ...so what could be it ?..bad fuel pump or coil?
Old 07-20-2011, 07:58 AM   #12
codyace
codyace's Avatar
Trader Rating: (58)
That part is ok, it's just a little vent to aide in the operation of the blow off valve -- it leaking doesn't effect how the car runs.
WHen this condition occurs, can you go WOT and the car continues to run, albiet off the 'limiter' sort to speak.
Old 07-20-2011, 08:02 AM   #13
NismoR003
NismoR003's Avatar
NismoR003 is an unknown quantity at this point
what do you mean it stops building boost?
does it maintain boost or it falls back to 0?
can you be more specific?
NismoR003 is offline   Reply With Quote
Old 07-20-2011, 02:25 PM   #14
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Oh, alright.
When it happens, yes the car continues to run, it doesnt turn off or sputter or anything. It just hits a wall. When the car is cold, it does not do this. I'm thinking maybe fuel pump....or coil harness?
The car hits a wall and does nothing...that's as specific as it can be explained haha.
Old 07-20-2011, 02:52 PM   #15
codyace
codyace's Avatar
Trader Rating: (58)
To check the coil pack harness you could check resistance and readings via Multimeter and FSM, I'd do that as if it checks out you can rule that out.
Member Jspaeth on here had an issue like this and his ultimately was solved by back probing the ECU pins and making sure they were making contact. I had a similar issue to this and it was a loose coupler, that had escaped my initial inspection of all couplers.
Aside from that, use the FSM to troubleshoot your main sensors....TPS, CAS, CTS, MAF and O2. It doesn't take long to check signal wire integrity.
Old 07-21-2011, 10:01 PM   #16
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
u should rewire ur fuel pump
with heavy duty wire and relay
definatly check ohms on coils
also check the two plugs that power engine harness
to see if all wires r getting full 12v...
also is the engine like gurgling at 5.5 k ?
or cutting off?
also do u have a tuned ecu ?
if so try a stock one and see wat happens
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 07-21-2011, 10:11 PM   #17
Sil-Eighty SE-K
Sil-Eighty SE-K's Avatar
Sil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfection
Send a message via AIM to Sil-Eighty SE-K
i say pump.... throw in a gauge and see hwat it reads at WOT when it happens
Originally Posted by JTunedMotorsports View Post
get off the thread...no one cares...
Sil-Eighty SE-K is offline   Reply With Quote
Old 07-21-2011, 11:28 PM   #18
sebastianwrx
Trader Rating: (18)
Coil harness checked theyre reading 12.5 in all 4...
Old 07-22-2011, 12:11 AM   #19
sebastianwrx
Trader Rating: (18)
or cutting off?
hi i was at my buddy car earlier and checked the ohm in coil harness,tps,injectors,...tps was fine ,injectors at .14, coil harness all of them are 12.5 and when u go half throttle it goes fine and pass without fuel cut except when its full throttle than it gets fuel cut exactly at 5000 sometime 5200..could it be fuel pump getting bad?
Old 07-22-2011, 08:01 AM   #20
codyace
codyace's Avatar
Trader Rating: (58)
I knwo plug gaps were checked, but what are they set at?
Old 07-22-2011, 08:26 AM   #21
sebastianwrx
Trader Rating: (18)
They were gap at .28
Old 07-22-2011, 10:43 PM   #22
JDMRIDDAZ
JDMRIDDAZ's Avatar
also i meant the ohms on the coil packs not just the 12v source they have to be 1k ohms
put a stock ecu on it and see if it happens again
Old 07-23-2011, 10:42 AM   #23
codyace
codyace's Avatar
Trader Rating: (58)
Try gapping them down to .022 and see if that fixes it up. It may be spark blow out. With the age of these components getting older and olrder, it's hard to say how capable a 20 year coil pack is anymore.
Old 07-23-2011, 10:54 AM   #24
KendallH
KendallH is an unknown quantity at this point
I'd bet 5 dollhair its the knock sensor
KendallH is offline   Reply With Quote
Old 07-23-2011, 11:23 AM   #25
codyace
codyace's Avatar
Trader Rating: (58)
Knock sensor shouldn't even be working at that point, it's sub 4000 IIRC
Old 07-23-2011, 03:53 PM   #26
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Alright guys.
- I checked ECU codes, there is no knock sensor code. I built the motor and the knock sensor is good, and the wiring to the knock sensor is good.
- Today I gapped the plugs from .028 to .025, and it's the same deal.
- I tried retarding and advancing the timing, like 20 different times. Was never any better or worse, it made no difference.
- I swapped my walbro fp into it, which I know is good because it powered my KA-T just fine, problem still persists.
At this point, I'm thinking it may possibly be the coil packs themselves being bad?
Kinda lost.
Old 07-23-2011, 04:22 PM   #27
codyace
codyace's Avatar
Trader Rating: (58)
Is there anyway you can get a video of it when it happens?
Old 07-23-2011, 04:32 PM   #28
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Yeah I can try next time I see the car.
Old 07-23-2011, 04:33 PM   #29
91s13shawn
91s13shawn's Avatar
91s13shawn is an unknown quantity at this point
My car is having the same exact problem! it cuts out/ hits a wall at 5000ish but when the car is cold it runs great. Please let me know if you find what the problem is i have been stumped for months.
91s13shawn is offline   Reply With Quote
Old 07-23-2011, 04:36 PM   #30
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Do you have an AVCR, Shawn?
I hope you say no, so I can rule that out as a problem lol.
