For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
![]() Join Date: Jul 2008
Trader Rating: (18)
![]() ![]() Feedback Score: 18 reviews
GT28 turbo
Up for grabs is this turbo. Came off my buddies Redtop and saw alot of track
Abuse. It is a godspeed unit..... It does need to be rebuilt due to 24+psi hard runs And the shaftplay it has now. Garrett and turbonetics make rebuild kits for around $40 for it. List of specs on it from godspeeds site: Maximum Horse Power 350-400 HP Inlet size 3" Outlet size 2" Type of Cooling Oil Cooled only Maximum PSI Capactiy 25 PSI (Default set at 14.5PSI) Type of bearing Wet float bearing Compressor/turbine size AR.60/AR.64 Compressor wheel Exducer: 71.32mm, Inducer: 54.28mm Turbine wheel Inducer: 52.90, Exducer: 45.47mm Downpipe flange type 5 bolt (SR20/CA18 downpipe) Type of Flange t25 Does not come w wastegate $100picked up or $116 shipped Text 661-400-6774 Notice the size diff next to the rb25 t28 and Garrett t3(both also for sale)
Trader Rating: (18)
Gt28 will bolt right up to a sr. It's all stock t25 flange and Sr 5 bolt exhaust. The t3 started blowing a little smoke before it was pulled off a buddies svo. It's also journal bearing.
