Old 01-23-2017, 07:49 AM   #1
aymaeid
aymaeid's Avatar
aymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-knownaymaeid is making his/her stupidity well-known
s14 JDM Turn Signal Question
After completing my Zenki>Kouki front end swap i realized the JDM signals i had purchased were missing their JDM wiring harness. After much searching, i realized i could use the oem zenki sidemarkers/ bulbs in the jdm lights. They fit perfectly! and work. unfortunately too fast. The blink rate is WAY too fast. probably twice as fast as normal. I'm looking to slow this down without having to purchase a jdm wiring harness. (especially since i cut my usdm pigtails too close like a jackass)
any help is always appreciated.
edit: i attempted to buy a second set of 194 bulbs and wire them to the harness. the blink rate on both bulbs is still fast.
Originally Posted by racepar1 View Post
Talking shit is half the fun of zilvia.
aymaeid is offline   Reply With Quote
Old 01-23-2017, 09:25 AM   #2
feito
feito's Avatar
Autozone sells a turn signal flasher that is compatible with led bulbs. Either way, it solves that problem. Go to The AZ website and look for a flasher for your car and make sure it says it works for LED lights. It will still be just a little faster than normal, but it works and it's cheap.
I believe i figured this out doing a little research when i switched to my jdm bumper, so next time do a little more research.
Old 01-23-2017, 10:35 AM   #3
andisan
andisan's Avatar
Yeah I bought that led flasher from auto zone and it solved my problem
It was easy fix to be honest
andisan is online now   Reply With Quote
Old 01-23-2017, 11:12 AM   #4
aymaeid
aymaeid's Avatar
thank you gentleman
