Old 12-24-2008, 02:30 PM   #1
xxmarcusrxx
xxmarcusrxx's Avatar
xxmarcusrxx has made poor choicesxxmarcusrxx has made poor choicesxxmarcusrxx has made poor choicesxxmarcusrxx has made poor choicesxxmarcusrxx has made poor choicesxxmarcusrxx has made poor choices
Weird Clutch, Throwout bearing problem HELP!
So I bought an exedy stage 2 clutch kit. Kit # 06953A. I put it in my 97' s14, since then the clutch fork has ben loose on the pressure plate. Like When everythings bolted up, I can move the fork back and forth a little. I didn't think much of it untill I went through 2 slave cylinders, they were over extending and blowing up on me . It seems like my slave is extending way too far to engage the clutch. Its basically fully engaged after I bleed the clutch, is this normal?. I did get the flywheel resurfaced, Is there such thing and grinding it too low?
xxmarcusrxx is offline   Reply With Quote
Old 12-27-2008, 04:43 PM   #2
FWD LOL
FWD LOL is an unknown quantity at this point
it is possible to install the throwout bearing backwards-that would require the slave to have to move farther- but it would not last long at all and you would be able to hear it. race clutches will shorten the engagment travel somewhat.
"Its basically fully engaged after I bleed the clutch, is this normal?"
dont understand this.
FWD LOL is offline   Reply With Quote
Old 12-28-2008, 01:46 PM   #3
ThunderbaySr20
ThunderbaySr20 is an unknown quantity at this point
you should be able to adjust your clutch pedal...
ThunderbaySr20 is offline   Reply With Quote
clutch, problem, throw out bearing, transmission
