Old 11-12-2012, 07:04 PM   #1
Knapik
Knapik's Avatar
Trader Rating: (36)
Knapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to all
Feedback Score: 36 reviews
Thumbs up Nismo SSS 2 way differential in S14 Pumpkin
Differential has been sold!
thanks
adam k
not anti-drift, just pro-grip
Knapik is offline   Reply With Quote
Old 11-19-2012, 12:56 PM   #2
Knapik
Knapik's Avatar
Trader Rating: (36)
bump..............
Old 11-20-2012, 07:02 PM   #3
Knapik
Knapik's Avatar
Trader Rating: (36)
bump!...shipping available
Old 11-30-2012, 07:02 PM   #4
Knapik
Knapik's Avatar
Trader Rating: (36)
last bump! new pricing! cooooome and get it
Old 11-30-2012, 08:53 PM   #5
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
I never heard of a Nismo SSS diff, how is this different fromt he Nismo GT ?
Big Zee is offline   Reply With Quote
Old 12-03-2012, 07:12 PM   #6
Knapik
Knapik's Avatar
Trader Rating: (36)
Originally Posted by MadScientist View Post
Kaaz offers parts to change the 1.5 to 2 way (vis-a-versa) but it requires being taken out and parts being added or removed. Its also not cheep.
Nismo GT Pro and GT Pro TT
Diff type - R200/R205
Differential system - 2 & 1.5 way, Internal pressure
Initial torque - Initial torque variable Functional attaching (6.5-8.5-14.0kgf)
Clutch plate quantity - 20
Clutch plate thickness - T = 1.5
Clutch plate - Grooved
The number of clutch plate nails - Inner 8 / Outer 16
Clutch plate Sliding area -
- Inner Major diameter (mm) 103.0
- Inner Inside diameter (mm) 59.0
- Outer Major diameter (mm) 104.0
- Outer Inside diameter (mm) 60.0
- Sliding area (mm2) 5505.0
Cam angle Drive side/coast side -
(GT L.S.D. Pro & GT L.S.D. )
- 2way: 55°/45°
- 1.5way: 55°/1°
(TT-model)
- 2WAY45°/45°
- 1.5WAY 45°/1°
L.S.D. Gear & Body - Precision forging make
L.S.D. Installing kit - Included
Note* the 45° Cam Angle on the TT model... faster corner exits and better control out of the turn.
Nismo GT L.S.D
Stats are the same as above only the Initial torque is Fixed @ 8kgf and the Diff Type is R200.
Nismo SSS L.S.D.
Diff type - R200
Clutch plate quantity - 16
Clutch plate thickness - T = 1.75
The number of clutch plate nails - Inner 6 / Outer 4
- Inner Major diameter (mm) 88.0
- Inner Inside diameter (mm) 54.0
- Outer Major diameter (mm) 90.0
- Outer Inside diameter (mm) 57.0
- Sliding area (mm2) 3530.4
- 2way: 55°/45°
- 1.5way: 55°/5°
Feeling like a Pimp... go and brush your sholders off!!
Peace
Drew
Old 12-13-2012, 03:11 PM   #7
Knapik
Knapik's Avatar
Trader Rating: (36)
bump.................
Old 12-26-2012, 10:25 PM   #8
Knapik
Knapik's Avatar
Trader Rating: (36)
need 2013 race season money....BUMP
-adam k
Old 12-26-2012, 10:59 PM   #9
jamg
jamg is an unknown quantity at this point
i would pick this up.
too bad you're not local.
jamg is offline   Reply With Quote
Old 12-27-2012, 10:55 AM   #10
Knapik
Knapik's Avatar
Trader Rating: (36)
shipping is $80 on average....and im willing to ship
