For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
05-15-2014, 02:19 PM | #1 |
Tuning on the cheap!! Apexi NEO ║ Harness ║ MSD BTM ║ Tach Adapter ║ z32 maf
Biting the bullet and selling my tuning set up....
The best of the cheap / universal / easy tuning options imo... APEXI NEO and MSD BTM are universal!! I used this set up on my sohc turbo. PROVEN set up. I personally know a handful of local drifters including myself using this set up with ZERO problems. This set up is easy to tune and very versatile...you can readjust tune with ease every time you upgrade your set up. Also can run a 'safe' tune when cruising the streets by just adding a bit more timing retard on btm and fuel points on the afc. Please contact at 714 305 4895. text for fastest reply. Will try to check PMs. feel free to ask questions. Will post pics asap. text it for some till then. -Apexi NEO in great condition. No issues. Screen in great condition. Comes with extension harness for easier wiring and easier screen placement. (can reach center console from ecu and have room to pull it out and tune with) Believe is still have the manual. and a wiring diagram for Ka24e and a s14 sr. But plenty of info is available online -MSD BTM boost timing master box. Box is a little scratched but works perfect. Knob controller in perfect condition. Comes with tach adapter and wiring ( just plugs into msd box simple install) so tach will still work. I ran this set up successfully with: (all on stock block) -stock sohc with basic bolt ons -sohc turboed running 8psi and walbro 255, atmospheric bov -sohc turbo with 460cc injectors, 14psi, gutted intake mani [no sensors, emissions, iacv etc..], and z32 maf in blow thru -sohc turbo with 550cc injectors, running e85, up to 20ish psi, gutted intake mani, ported head, and z32 maf in blow thru SOLD for both. + harness and tach adapter do not really want to split and they really should go hand in hand for best tune. -also have injectors and other turbo parts avail on my other forsale thread -OEM z32 maf with pigtail and adapter to be run in blow through config. just dictch adapter to run in draw thru.. screen has no rips, tear, bends....tiny bit of gasket on out side of screen (used to seal up for blow through) doesn't affect anything. And top epoxied also for blow thru use OEM maf not shitty reman or knock off. $75
Braaap Last edited by zeebrah; 06-02-2014 at 04:42 PM.. |
Tags |
apexi, maf, msd, tuning, z32 |
