Old 11-12-2013, 01:32 PM   #1
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enough
Feedback Score: 105 reviews
Arrow Lots of S14 Parts! 70 Pictures! Everything $60 or Less! Check it Out!
I am listing some s14 parts I have in my shop and no longer need. Post a reply or send me a PM if you see anything you like. I will ship, just leave zip code for quotes. I accept paypal and ship fast.
S14 sun visors-$30 for pair
S14 black left side seatbelts (don't have right side)
Front-SOLD
Rear-$15
S14 airbag harness-$25
S14 SRS air bag control unit-$30
S14 black A pillars-$30 for pair
S14 dark green SE A pillars-$20 for pair
S14 black B/C pillars-$30 for pair
S14 dark green B/C pillars-$20 for pair
S14 black left side rear panel-$15
S14 dark green rear panels-$25 for pair
S14 dark green steering column cover-$20
S14 black upper steering column cover-SOLD
S14 dark green gauge cluster bezel-$20
S14 black gauge cluster bezel with switch-$30
S14 black glove box w/ bracket-$40
S14 glove box bracket-$15
S14 black kick panels (no fuse box cover)-$25 for pair
S14 dark green kick panels-$25 for pair
S14 dead pedal-$10
S14 hazard and defrost buttons-$10 each
S14 mirror switches (95 and 96)-$15 each
S14 dimmer switch-$15
S14 blanks-$5 each
S14 OEM shift knob-$15
S14 gas pedal-$15
S14 ECU bracket-$25
S14 radio/stereo brackets-$25
S14 light switch-$30
S14 cruise control cable-$20
S14 cruise control switch-$10
S14 cruise control module-$30
S14 cont assy entrance unit-$40
S14 alarm hood sensor-$25
S14 hood emblem-$10
S14 door lock actuators-$20 each
S14 door lock timer-$20
S14 front speaker grills-$10 each
S14 OEM Clarion amplifier-$20
S14 radio/stereo harness-$20
S14 ignition switch-$20
S14 complete rear interior harness-$60
S14 sunroof switch and map light-$20
S14 dome light-$15
S14 side markers (small crack on right side)-$25 for pair
S14 license plate lights-$20
S14 right side mirror (small crack on bottom)-$20
Driver side door handle-$20
S14 95 grill (broken bottom mounts, top mounts work)-$20
S14 gas lid/door-$15
S14 trunk and gas lid release cable w/ lever (complete)-$35
S14 hood release cable w/ lever-SOLD
S14 hood hinges-$25 for pair
PM me for s13 or s14 parts!
s13 drifta is offline   Reply With Quote
Old 11-12-2013, 01:33 PM   #2
s13 drifta
s13 drifta's Avatar
S14 fuse box cover (letters worn)-$15
S14 fuel pump-$20
Ka24de throttle body bolts-$5 for 4
S14 E brake assembly-$30
S14 brake booster vacuum line-$15
Brake booster valve-$5
Ka24de FPR-$15
S14 ka24de fuel rail with injectors and caps-$60
S14 power steering hardline (works for dohc s13)-$40
S14 OEM heater core (works well)-$20
S14 A/C evaporator unit-$40
S14 A/C high pressure line-$20
S14 wiper arms w/ good blades-$40 for pair
S14 wiper motor-$25
S14 (95-96) windshield wiper amp-$25
S14 OEM hollow cat-$40
S14 radiator brackets-$25 for pair
S14 lower radiator shroud-$10
S14 clutch fan-$35
S14 steering shaft U joint-$15
S14 gas tank-$150
S14 gas tank straps-$30 for pair
S14 fuel sending unit-$50
S14 OEM fuel pump-$25
S14 filler neck with cap-$25
S14 rear subframe-$150
S14 open differential-$70
S14 axles-$40 each
S14 rear lower control arms-$40 each
S14 toe and traction rods-$10 each
S14 E brake cables-$25 for pair
S14 4 lug hubs-$20 each
S14 4 lug rotors-$10 each
S14 OEM rear windshield w/ defroster-$120
Thanks for looking!
Old 11-12-2013, 08:25 PM   #3
NissanS141
NissanS141 is an unknown quantity at this point
Would you do 30$ for hood cable and radiator brackets shipped to 85041?
NissanS141 is offline   Reply With Quote
Old 11-13-2013, 06:12 PM   #4
s13 drifta
s13 drifta's Avatar
No, you are looking at $50 plus $10 for shipping. I can do $30 shipped for one item.
Old 11-13-2013, 07:16 PM   #5
John912345
John912345 is an unknown quantity at this point
Iff a the "blanks" are black I'll take all 4 and the black upper steering Column cover for 50 shipped to 21710? I respond to text better, 3016392139
1995 ls1 240
John912345 is offline   Reply With Quote
Old 11-13-2013, 10:18 PM   #6
Josephj
Josephj is an unknown quantity at this point
How much for the hood cable and latch plus the FLCA if u have em shipped to 07307? Thanks
Josephj is offline   Reply With Quote
Old 11-13-2013, 11:56 PM   #7
Cisco357
Cisco357 is an unknown quantity at this point
E brake shipped to 92591 mang!
Cisco357 is offline   Reply With Quote
Old 11-14-2013, 06:50 AM   #8
MrsFieldsKOUKI
MrsFieldsKOUKI is an unknown quantity at this point
Send a message via AIM to MrsFieldsKOUKI
have ka dual cam maf?
MrsFieldsKOUKI is offline   Reply With Quote
Old 11-15-2013, 05:58 PM   #9
s13 drifta
s13 drifta's Avatar
I have the hood release cable for $32 shipped.
$30 plus $15 shipping
I don't have a s14 MAF, let me know if you need anything else.
Old 11-15-2013, 06:11 PM   #10
UkCobra
UkCobra is an unknown quantity at this point
Do you happen to have the door ajar button for the drivers side door?
UkCobra is offline   Reply With Quote
Old 11-15-2013, 06:30 PM   #11
ReLiC
ReLiC is an unknown quantity at this point
I may need the wiper amp. Is it off a base or se model? Also, you wouldn't happen to have the pigtail for it would you? thanks
ReLiC is offline   Reply With Quote
Old 11-17-2013, 08:17 AM   #12
s13 drifta
s13 drifta's Avatar
Yes I do.
I have both, just let me know what you need. No pigtail.
Old 11-17-2013, 08:28 AM   #13
jerry_beans
jerry_beans is an unknown quantity at this point
Driver side window motor by any chance?
IG @jerry_beans_
jerry_beans is offline   Reply With Quote
Old 11-17-2013, 05:26 PM   #14
s13_ricky
s13_ricky is an unknown quantity at this point
Bump for a good selection of items and clear pictures!
s13_ricky is offline   Reply With Quote
Old 11-17-2013, 05:28 PM   #15
Josephj
Payment sent for the ignition switch
Old 11-25-2013, 07:06 PM   #16
s13 drifta
s13 drifta's Avatar
No, don't have the driver side. Just pass side.
Thanks, I have more parts that aren't pictured too.
Old 11-28-2013, 06:33 PM   #17
j's
j's is an unknown quantity at this point
Do you still have fuse box cover?
Sent from my C5306 using Tapatalk
j's is offline   Reply With Quote
Old 12-08-2013, 08:13 AM   #18
s13 drifta
s13 drifta's Avatar
Yes, I do. $30 shipped to Canada.
Old 12-08-2013, 10:57 AM   #19
nextproject
nextproject is an unknown quantity at this point
Have you updated this thread with whats been sold? Just sent PM regarding the leftmost (drivers side) blank plate for below the center vents.
nextproject is offline   Reply With Quote
Old 12-28-2013, 11:49 PM   #20
s14sliding
s14sliding is an unknown quantity at this point
you have the front lower control arms by any chance?
s14sliding is offline   Reply With Quote
Old 09-02-2018, 07:00 PM   #21
Timmy_s13
Timmy_s13 can only hope to improve
Your my only hope. Lmfao
Is all your s14 off a RHD? If so I need the glove box bracket iv looked for days and this is my only hope. I have a s13 I’m not sure if it will fit but for 15$ I’ll try. And the high pressure line for the ac. 28425 is the zip
Timmy_s13 is offline   Reply With Quote
Old 09-02-2018, 07:07 PM   #22
Timmy_s13
Do you still have the parts?
Old 09-02-2018, 09:19 PM   #23
Po_31
Po_31's Avatar
Trader Rating: (28)
Po_31 has a spectacular aura aboutPo_31 has a spectacular aura aboutPo_31 has a spectacular aura aboutPo_31 has a spectacular aura aboutPo_31 has a spectacular aura aboutPo_31 has a spectacular aura about
Feedback Score: 28 reviews
Do you still have the ignition switch.
Po_31 is offline   Reply With Quote
Old 09-03-2018, 08:58 PM   #24
xchaosx
xchaosx's Avatar
xchaosx is an unknown quantity at this point
Do you have both door handles?
xchaosx is offline   Reply With Quote
Old 11-12-2018, 10:12 AM   #25
nnoriega
nnoriega is an unknown quantity at this point
Do you have a Passenger side S14 Lower control arm and knucle?
Thanks
nnoriega is offline   Reply With Quote
Old 11-12-2018, 10:59 AM   #26
miswuevos
miswuevos is an unknown quantity at this point
pmed about the s14 fuel sending neck.
Thank you,
miswuevos is offline   Reply With Quote
Old 11-12-2018, 11:12 AM   #27
Agamemnon
Agamemnon's Avatar
This post is from 2013 people. Check your dates before making a reply.
Agamemnon is online now   Reply With Quote
