Old 01-17-2010, 09:53 AM   #1
Speedstyles408
Speedstyles408 is an unknown quantity at this point
fender rolling/pulling question
hey i'm a newb at this i got a s13 hatch and i'm tryin to fit 17x9 +0 wheels curious how much of a roll or pull i would need and how much negative camber i would also need thanks for any help
Speedstyles408 is offline   Reply With Quote
Old 01-17-2010, 10:20 AM   #2
davirene
davirene's Avatar
davirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nice
Your tires and your stance are what you should consider....Dont roll until you have the tires and the look you want. I have 18x9.5 with a stretched tire. I have about a 3 inch drop all around. I also have a 14mm spacer on the front with a custom made 31mm spacer on the back.
This pic was right before I put the spacers on the rear and before I lowered it.
davirene is offline   Reply With Quote
Old 01-17-2010, 12:40 PM   #3
Speedstyles408
well i'm basically trying to tuck tire on the rears and the fronts i'm tryin to run a 215-45 if i wanna run a 215-40 . thats the stance i'm lookin for
Old 01-17-2010, 12:45 PM   #4
HPballer76
HPballer76's Avatar
HPballer76 is an unknown quantity at this point
just put on your wheels and tires and roll/pull till you have the stance you want..
HPballer76 is offline   Reply With Quote
Old 01-18-2010, 08:23 AM   #5
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
To roll or pull your fenders is BECAUSE you are rubbing somewhere. If your not rubbing, no need to roll or pull your fenders.
So how about you put your wheel/tires on, drive around and check to see if your rubbing. Then roll/pull what is necessary.
Maiku240sxS14 is offline   Reply With Quote
