Old 12-11-2017, 10:21 PM   #1
2jz300
2jz300 is an unknown quantity at this point
FS: random 1jz/2jz turbo parts. more to be added.
email: [email protected]
phone#: 780-940-8561
city: Sherwood Park
Province: Alberta
Country: Canada
below is a 2jzgte hks 2835 twin turbo kit. asking $6500CAD + shipping
**WILL NOT SEPERATE**
finally got around to getting a complete pictures of EVERYTHING i have for this kit. so as follows:
-(2) hks 2835 turbos with 0.61ar silver ceramic coated exhaust housings and polished compressor housings (need rebuilds as they have touched housings as pictured)
-(2)hks 2835 turbos with 0.73ar black ceramic coated exhaust housings and original compressor housings.(minimal play)
- hks "Y" hotpipe and turbo elbows ceramic coated silver.
- hks "Y" hotpipe and elbows polished and modified elbow for hks ssqv positioning.
-original turbo oil drain hardpipes for kit with dual return flange to pan
-ceramic coated silver downpipes with wastegate recircs
-hks 4 bolt wastegates for kit (not sure on the size of these)
-ceramic coated black hks exhaust manifold set with junction pipe (gaskets were cut to replace originals, should work)
-hks braided steel oil supply hoses and fittings
-(2) vibrant 4 bolt turbo outlet flanges in mild steel
-(2) vibrant 4 bolt turbo outlet flanges in stainless
-(2) hks polished turbo heat shields
-(1)hks green mushroom air filter
-(2) performance world -10 weld on AN bungs for turbo custom turbo drains
-(4) performance world -10AN black fittings to build hoses
-(2) vibrant turbo drain -10AN flanges
-(4) vibrant black couplers for turbo hot side pipes
-(2) genuine hks wastegate outlet gaskets
-(2) genuine hks turbo outlet gaskets
- new turbo inlet gaskets
-new wastegate inlet gaskets
-(3) custom made mild steel wastegate outlet flanges(1 has a vband already welded)
-(2) vibrant stainless vband assemblies
-(1) custom chrome turbo inlet pipe
-will include the originally removed gaskets
-new hardware on pretty well everything
-individual ports on runners for exhaust temp sensors. (all plugs installed at the moment)
-kit still needs some work but minimal. I didn't get to complete it as i lost interest. --still need to: build the one intake pipe, 2 water return lines, need 1 air filter assembly, need to make a collector from the 2 downpipes, needs hose clamps or T-bolts for couplers, and will have to build the return hoses if you'd like to do AN line rather than the original steel pipes.
-I dont have a 2jzgte anymore so there is no need to keep these around for myself. Asking $6500 CAD for them. Will ship at buyers expense. please pm or text me 780-940-8561
If seriously interested i have more photos that i can send you by email.
next is for a 1jzgte:
-hks3037 single turbo kit. ball bearing. could use rebuild as there is play. manifold. 50mm hks 4bolt wastegate.
-oldschool hks fcon with patched in 1jz harness.
-clutchmasters twin plate clutch. used.
-1jz/2jz front sump oil pan setup. as well as a rear sump setup. both used and dirty.
-$2000CAD FIRM for the above **WILL NOT SEPERATE**. will ship at buyers expense. pictures will be taken of these 1jz parts soon.
-1jz to bmw e36 engine mounts (dont know brand) $150
2jz300 is offline   Reply With Quote
1jz, 2jz, nissan, toyota, turbo
