Old 07-31-2012, 09:35 PM   #1
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
AAC / FICD wiring question
Hello i have an red top sr20det in an s13. I am trying to clean up any unneccesary wirings in my engine bay. can anyone tell me what the blue with red tracer wire that goes to the AAC (aux air control) / FICD (fast idle control device) is used for? If you are looking at the intake manifold from the passenger fender it is the top left pin. I traced it back to a 6 pin connector that is un used. I would assume it would be fine to remove, i would just feel better knowing exactly what it is before removal. thank you
g2ic02 is offline   Reply With Quote
Old 08-01-2012, 04:32 PM   #2
g2ic02
or does anyone have a good wiring diagram with wire colors. all i can find is the pcm diagram and i only have the s14 sr20det fsm.
