For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
01-17-2014, 06:57 PM | #1 |
Extremely Large Sale, Huge List of Parts, some hard to find, TAKE A LOOK!!!!
ALL PURCHASES COME WITH INSURANCE, TRACKING INFORMATION, AND LEGITIMATE PACKAGING.
Some sellers are so terrible that is actually makes a difference to say that... Shitty isn't it? Text me for questions, info, or ask if I have something you need. TEXT ME PLEASE - 361-571-1026 DEAN NEW PARTS TO THE LIST: S13 Climate Control (Mint Condition) - $40 shipped S13 Rear Side Marker Lights - $20 shipped ea $30 shipped for both S13 KA24DE MAF - $40 shipped S14 KA24DE Distributor - $65 shipped S13 Power Window Amp - $20 shipped S13 Fuse Box Pigtails - $10 each shipped S13 Heads Up Display Projector (ONLY the projector BY ITSELF) - $15 shipped 7/10 S14 SE door panels - $60 pickup only S14 Headliner - $50 pickup only S14 Center Console - $40 shipped $20 picked up S14 A-Pillar plastic trim - $30 pick up only S14 Glove Box - $45 shipped $30 picked up S14 Rear Seat - $40 pick up only S14 dash in bad shape - $40 pick up only S14 steering column plastics - $35 shipped $20 picked up S13 KA24DE Distributor (Great Condition) - $60 shipped PowerSlot S14 Brake Rotors REAR PAIR (Freshly Turned for the first time) - $80 Shipped S14 OEM Mint Headliner - $60 picked up S14 OEM E-Brake Cables (GREAT Condition, 101,000 miles, no e-brake drifting) - $65 shipped S13 OEM E-Brake Cables (GOOD Condition, not stretched) - $60 shipped S13 KA24DE Engine Harness Pigtails - PM me what you need $15 shipped each -S13 Door Handle Trim (L + R) - $20 shipped for both -S13 License plate light assembly - $25 shipped -S13 Window Amp - $25 shipped -S13 Ash Tray - $20 shipped -S13 Passenger Side Power Window Trim with switch - $20 shipped -KA24DE Oil Cap - $15 shpped -Driveshaft carrier bearing top half - $10 shipped -S13 Hatchback Trunk Light - $15 shipped -KA24DE Fuel Injector Caps - $15 shipped for 4 -S13 Door Handle Trim - $15 shipped -240sx Gas Cap - $15 shipped -S14 KA24DE Valve Cover Bolts (Silver painted heads) - $15 shipped -2.5" Clamps - $15 shipped for 4 S13 Fuel Pump Harness Metal Cover - $15 shipped S13 Pop-Up Headlight Motor Covers - $10 shipped per pair S13 Wheel Studs - $15 shipped for 8 S13 Gas Pedal Assembly - $20 shipped KA24DE/E Oil Filter Block - $20 shipped 240sx steering shaft U-Joint w/ bolts - $25 shipped 240sx Power Steering Rack Brackets w/ bolts - $25 shipped KA24DE Fuel Injector Bushings - $8 shipped for 4 KA24DE Cam Sprocket Bolts w/ washers - $10 shipped per pair 240sx Shock absorber cap - $5 shipped 240sx Hub Cap - $8 shipped S14 OEM Diff Bushings - $10 shipped KA24DE Oil Pump Drive, Key-way, and Bolt w/ washer - $15 shipped S13 Passenger Side Kick Panel - $18 shipped 240sx Shifter - $20 shipped 240sx Radiator Hold Down Brackets - $15 shipped per pair KA24DE Oil Filter Block Gasket OEM - $8 shipped KA24DE Throttle Body Gasket - $5 Shipped KA24DE Coolant Temp Sensor - $8 Shipped each S13 Radiator Bushings - $10 shipped per pair S13 89-90 Dash Connector Pigtail Chassis Side - $10 shipped KA24DE Flywheel Bolts - $20 shipped for 6 3" 2-Bolt Exhaust Gasket - $5 shipped T25 Turbo Inlet Gasket - $5 Shipped KA24DE/E Throttle Position Sensor - $15 shipped KA24DE Spark Plug Clips Perfect Condition - $15 for all 4 shipped S13 Rear Side Marker Lights w/ harnesses - $15 shipped each S13 Hatchback Trunk Trim - $20 picked up S13 Front Crossmember - $60 picked up IMG_0728 by Dean Chinowith, on Flickr S13 Fusebox Bracket Engine Bay - $20 shipped IMG_0729 by Dean Chinowith, on Flickr S14 Power Steering Reservoir - $30 shipped IMG_0730 by Dean Chinowith, on Flickr S13 Power Window Glass - $20 Picked Up IMG_0731 by Dean Chinowith, on Flickr S13 Hatchback Tail Light Garnish - $20 picked up IMG_0732 by Dean Chinowith, on Flickr 91-94 S13 Dash Harness Pigtail (Chassis Side) - $15 shipped IMG_0733 by Dean Chinowith, on Flickr KA24DE 5-Spd Transmission Gussets - $25 shipped (Only because they're heavy) IMG_0737 by Dean Chinowith, on Flickr S13 Hatchback Tail Lights - $55 shipped IMG_0738 by Dean Chinowith, on Flickr S14 Steering Wheel Plastic Trim - $30 shipped S14 Under Steering Wheel Dash Plastic - $30 shipped S14 Center AC Vent - SOLD S14 AC Tubes - $20 shipped S14 Drivers Side Kick Panel - $20 shipped S14 Glove Box - $35 shipped S14 Power Window Switch Trim L + R - $15 shipped ea S14 Dead Pedal - $15 shipped S14 Door Handle Trim L + R - $10 shipped ea S14 Center Console - $20 picked up S14 Drivers Side A-Pillar Plastic - $10 picked up IMG_0739 by Dean Chinowith, on Flickr S14 E-Brake Cables 101,000 Miles Never Used For Drifting - $50 Shipped S13 E-Brake Cables in good shape - $45 shipped 240sx Throttle Cable - $30 shipped S14 Auto Shifter Lock Cable - $15 shipped IMG_0740 by Dean Chinowith, on Flickr KA24DE AC Compressor Mint Condition (Pulled working perfectly 9-14-13 - $60 plus shipping S13 Under Steering Wheel Dash Panel - $25 shipped S14 Gauge Cluster Trim - $30 shipped S13 Hatchback B-Pillar Exterior Trim L + R - $20 shipped IMG_0747 by Dean Chinowith, on Flickr S14 OEM Rear Sway Bar - $60 plus shipping - Zenki S14 Front Grille - $40 shipped - $20 picked up -S14 OEM Suspension (great shape, 80,000 miles) - $40 plus shipping - S14 climate control - $35 shipped $20 picked up - S13 Headlights Brackets - 40 shipped IMG_0314 by Dean Chinowith, on Flickr - KA24DE Crankshaft (No damage, no bullshit) - $80 Picked up ALOT shipped IMG_0326 by Dean Chinowith, on Flickr Last edited by drifter92; 01-27-2014 at 08:17 PM.. |
01-25-2014, 11:50 PM | #8 |
Work Rezax
I have a set of work relax for sale, hit me up for price
https://post.craigslist.org/manage/4265295964 |
01-26-2014, 03:20 PM | #9 | |
01-26-2014, 07:25 PM | #13 |
wondering if you had the driver side power window switch for s14. Also the drive side power window/handle trim, what condition is it in and is it black? Shipping would be to 97007.
